will car turn ON without PCM?
Just turning it over though, you won't get good oil flow to the bearings (crank,cam, rods).
Most of the lights on the outside of the car, shouldn't need any modules, except for the DRL module, flashers, etc. but the interior lights and functions will need the BCM, etc.
The turn signals, DRL's are controlled by a separate assembly called the DRL module which is behind the radio. The headlights and bright lights have nothing to do with the PCM or BCM..
