Sponsored by: CARiD
No Signal for Starter
Old Oct 25, 2017 | 09:48 AM
micbegz28's Avatar
Default No Signal for Starter
Hey Guys, winding down my build and just trying to work out some final kinks.
It started life as a LS1 6 speed car, purchased as a roller and now is a LS1/4L60e car, and i think that may be were some of my problems lie. The PCM is a Auto PCM, the engine harness is an auto harness, however the body harness is a modified 6 speed one.
First thought is my problem lies with the wiring to adapt the clutch switch, starter relay coil or neutral safety to work with the 6 pin A4 shifter plug. All info on this wiring can be found in my thread here
https://ls1tech.com/forums/automatic...ification.html
Anyways, heres the issue
The starter itself is getting power, the relay is getting power, but there is no signal to the relay when the key is turned. To get the car started as a test, i just used a piece of wire to jump the relay. Car started right up. That proved that the ignition relay was a good relay, so i swapped that with the starter relay to see if maybe it was just a bad starter relay, and still nothing.
Anyone ever run into any issues like this ?
Old Oct 25, 2017 | 11:59 AM
biketopia's Avatar
Possible VATS issue? Have you checked the wire coming out of the theft module?? I also thinking back to bypassing all the stuff on my LT1 car, so it may be wayyy different on an LS car. I'd have to look at the wiring diagram.
Old Oct 25, 2017 | 12:24 PM
micbegz28's Avatar
I dont believe it is a VATS issue. The fuel pump didnt want to kick at first either, but then we wiped VATS with HPTuners and the pump kicked on. Still nothing for starter however.
Old Oct 25, 2017 | 12:51 PM
micbegz28's Avatar
There is power at the 85 and 30 pin of the relay, 87 goes to the starter, 86 goes to the BCM, which is the ground.
So what it looks like, to me atleast, the key isnt grounding out the relay. Thus no complete circuit.
However if were to ground out the 86 pin, would that render it on at all times?
Old Oct 25, 2017 | 06:03 PM
peterpar's Avatar
Pins 85 and 86 control the coil of the relay which closes the contact of the relay to energize the starter solenoid. If you were to ground pin 86, the relay would stay energized as long as the pin was grounded. I'm not familiar with HP Tuner software, but is it possible only the fuel pump enable was bypassed? The start enable is the ground path through the BCM to coil of the start relay and if the bypass didn't include enabling this operation, that could explain what you're experiencing.
File Type: pdf
Old Oct 26, 2017 | 06:30 AM
micbegz28's Avatar
It is possible. I dont have HPTuners myself, and im not very familiar with it. My buddy has it and he was the one that did it for me.
If it is the VATS, i should be able to bypass with a resistor then, correct?
Old Oct 26, 2017 | 05:55 PM
peterpar's Avatar
After looking at the attached diagram, I would think HP Tuner software may be able to bypass the BCM signal to enable the starter relay just like the fuel pump. Doing the VATS bypass should accomplish the same result as the software bypass.
File Type: pdf
Old Oct 30, 2017 | 09:38 AM
WhiteBird00's Avatar
Ungrounded Moderator
No, it is impossible to completely tune out VATS with HP Tuner or any similar program. You can program the PCM to ignore the missing fuel enable signal from the BCM (where VATS is) but the BCM is not programmable and VATS physically controls the ground signal for the starter relay coil in the BCM. Yes, you could do a VATS bypass with resistors but in this case it would be easier to simply provide a constant ground for the starter relay coil so that the BCM no longer controls it. All that's necessary is to cut the yellow/black wire under the starter relay socket and connect the relay end of the wire to a good chassis ground.
Old Oct 30, 2017 | 03:19 PM
micbegz28's Avatar
I ended up getting a resistor to by pass it, but sadly im having some new problems now.
Old Nov 3, 2017 | 12:45 PM
chrysler kid's Avatar
I came out of lurking just to repeat this
I've seen vendors and site sponsors advertise vats delete.
You can not delete vats from the BODY Control module, or from an Fbody. Drives me crazy people asking some one to tune it out of their fbody
