flushing and cleaning a clogged O2 sensor?
My O2 sensor is used for 150K miles in my 2011 2.5L 4 cylinders Toyota Camry and it has one O2 sensor only.
I tried to soak the O2 sensor in apple cider vinegar and lemon juice. I even tried to remove the carbon deposits on the O2 sensor by soaking it in boiling apple cider vinegar but it was not working well!?
Does it need to remove all of the carbon deposits on the O2 sensor to soak it in lemon juice or apple cider vinegar for one full day or so?
Any one can help.
These new modern O2 sensors are expensive to be bought new.
maybe I need a fine wire brush and not a coarse wire brush to not scratch the O2 sensor.
I.e. goto the junkyard and grab any number of used/free narrowbands to walk out with. You can use any of them in your car you want. No need to clean them or spend $$$.
Or just buy the cheapest new one they sell, goto any auto store, look through all their sensors, pick the cheapest one. Even just 1 wire sensor would work. Plug that 1 single signal wire to the correct O2 sensor input on the ECU and it will work.
Your Toyota has fewer oxygen sensors because it is a 4 cylinder and has only one exhaust bank. It also probably has 2 sensors, if you still have a catalytic converter installed. (The first one tests engine combustion and the second tests catalytic converter efficiency.)
The oxygen sensor is built similar to a very complicated spark plug. It has a number of fragile metal/layers inside the plug, which are protected by the cap. (So, cleaning the outside of the cap does nothing!!!)
Your exhaust gas is corrosive. Over time, the metals inside erode and also get contaminated with carbon. There are some special tools and chemicals that will clean the carbon - but they will cost you more than new sensors. (You need the special tools, because the chemicals that clean carbon will dissolve the wires and plastic parts on the sensor.)
Even then... if you were to clean the carbon off your current sensor, you still have 150,000 miles of exhaust wear on the plug.
Your plugs are trash and completely worn out by now. You have to get new ones in order to restore the performance of the car.
Clean the inside of your exhaust pipe - without scrubbing. If you can't do that, you are never going to be able to clean the inside of your Oxygen Sensor. (It sits inside the pipe and picks up the same contamination, except worse because its hotter and closer to the engine.)
to reach that sensing element I have to cut the covering of the O2 sensor with the holes and being very careful to not cut the O2 ceramic sensing element inside.
then cleaning O2 sensing element from the carbons deposits on it with soft metal brush, 1000 grit sanding paper and MAF sensor cleaner ( being careful to not damage the O2 sensing element ).
then cutting and tac welding threads ( just like the threads on bolts and nuts ) to the metal cover covering the O2 sensing element.
I'm planning to add threads to the cover of the O2 sensing element so that when every 30000 miles/50000 kilometers when needing to clean the sensing element to reach it ( the sensing element ) easily without hassles.
then trying that sensor.
I will try that when God will ( In sha'Allah ).
Good luck with trying to clean them!
