walk me through a steering rack check up
lots of power steering and various steering rack issues with fbodys. i have a 2000 ss with 105,000. id like if u guys could help me inspect my steering system and let me know the steps i could do to inspect stuff.
last year it got new inner and outers, has new upper and low joints as well. all moog problem solver. also inspected my steering rack boots and they are intact looking good.
1) should i siphon out the power steering fluid? add in new, drive for awhile, then siphon out again and put in new fluid? or is that not necessary?
2)with car off, if i turn the wheel between 11 and 1 o clock i do here a light knocking noise assuming from the intermediate.......
so what steps would you guys recommend me doing?
As preventative maintenance, you can opt to change out your power steering pressure line (then end up going bad and seeping fluid). When you do that you will be able to drain out your reservoir and refill with fresh fluid. If you have a power steering cooler, you may want to remove it and replace the radiator hose with a non-cooler line (they fail and mix coolant and ps fluid, also the cooler is not necessary).
Save the manuals!
Once all of that is done, you can flush out the system. The easy way I like to do this is have several open bottles of open P/S fluid handy and a helper.
- Disconnect the return hose, clamp it to the rim of a bucket so it drains in. (After you remove the cooler, this should come straight out of the rack.)
- Put a cap on the drain nipple of the P/S fluid reservoir or use an extra piece of tube and bend it up so the open end is above the inlet of the tank. Fill the tank with new fluid.
- Have a helper turn on the car and quickly turn the steering lock-to-lock. This will bleed out the air and flush out the old fluid. As this happens, the other person keeps topping off the fluid in the reservoir as the used fluid drains to the bucket.
^ Warning: ^ this goes FAST. (The pump moves a lot of fluid.)
- Keep going until the fluid runs clear into the bucket. (You might also use a milk jug so you can see.)
^ As you do this, you need to be really careful that the pump doesn't run dry, so make sure the helper is ready to cut the engine right away when you either run out of fluid, or are done with the flush.
