Sponsored by: CARiD
Goodbye starter.
Old Apr 18, 2018 | 12:31 PM
Shadyredeyes81's Avatar
Default Goodbye starter.
So I started my car the other day and heard a really bad rattle. After starting it about 4 times it finally decided to stop turning over at all. So I pulled my starter and this is what I found.....
Old Apr 18, 2018 | 12:53 PM
jaxcam02's Avatar
at least it was the starter and not the block
Old Apr 18, 2018 | 01:47 PM
BALLSS's Avatar
Many, including me, get the "corvette" (96) starter. It is a gear reduction type, smaller, lighter & cheaper
Old Apr 18, 2018 | 02:07 PM
Chrisingermany's Avatar
Yeah and just a heads up plenty of people have broken the ear off the block when something like this happens. I would get the newer style starter with the long bolt on both sides.
Read up: https://ls1tech.com/forums/general-m...ock-broke.html
Old Apr 18, 2018 | 02:08 PM
fst100's Avatar
definitely times 2.
i'd go and get the truck starter that has both elongated bolts.
Old Apr 18, 2018 | 02:27 PM
BALLSS's Avatar
OP
this a LT1 car?
Old Apr 18, 2018 | 03:10 PM
ss.slp.ls1's Avatar
Originally Posted by ******
OP
this a LT1 car?
Looks like an LS1 starter to me.
Old Apr 18, 2018 | 04:52 PM
BALLSS's Avatar
..yeah but his sig says 96 car...
Old Apr 19, 2018 | 07:37 PM
It is an LT car. I put another starter in it, and it's still locking that starter up too.
Old Apr 20, 2018 | 11:11 AM
ss.slp.ls1's Avatar
Huh, I thought it was an LS starter for sure. *facepalm myself*
If your new starter is not turning over, I would remove your spark plugs and see if your engine turns over regularly. You might have a leaky injector or blown head gasket that has hydrolocked the engine. I hope you haven't bent anything if that is the case.
Old Apr 20, 2018 | 11:16 AM
There's a good chance it could have been an LS starter. The guy I bought it from wasn't the sharpest tool in the shed when it comes to these cars.
Old Apr 20, 2018 | 11:23 AM
I don't think the engine is hydrolocked. The used starter I put in started up the first time I cranked it. Then acted like it was locked up again a few hours later. I tapped on it with a hammer and it turned right over again. I'm hoping it's just an issue with using stock starters to try and turn a higher compression engine. I'm gonna put a Corvette starter on it and see it that helps.
Old Apr 20, 2018 | 11:40 AM
biketopia's Avatar
Starter from a 99-04 4.3L s10 is a "factory" high torque mini starter. Think I picked up one from my local jobber for $65 bucks at our contract pricing with core exchange.
