A/C Expert...Oriface Tube Question PLEASE...!
Hello,<br /><br />I have looked everywhere possible with no luck. I have 2001 Camaro SS. I'm replacing the Compressor, Accumulator/Dryer, and OT. I have my new AC Delco Oriface Tube, but it came with no O-ring or Gasket. So, when you undo the connection to replace the OT, do you have to replace what ever medium seals that connection? I DO know where the connection and OT is, and something has to be sealing that connection. Thank you for any assistance.
- SERVICE AND REPAIR
REMOVAL PROCEDURE
- Recover the refrigerant.
- Remove the air conditioning (A/C) evaporator.
- Remove the orifice from the A/C evaporator tube.
IMPORTANT: Install the long screen inlet end toward the condenser.
- Install the orifice in the A/C evaporator tube.
- Install the A/C evaporator.
- Recharge the A/C system.
- Leak test the fitting for leaks.
If you are talking about inside the tube, the interior of the tube holds the orifice in place.
If you are talking about the seals for the outside of the aluminium line that connects to the rest of the AC system, you should always replace the gaskets/o-rings of any AC component that is removed. You can get them at just about any auto parts store. The kit for the entire AC system is like $15.
