Car won’t stay running
hey guys
When I go to start my car it runs briefly then shuts off and is hard to keep running. The MAP sensor code comes up even though I just replaced the MAP. I know the standard issue would be a vacuum leak. I’ve changed the MAP, intake/intake gaskets, injector o rings, checked the wiring connection for the MAP, and examined my PCV lines. All of that is good.
very frustrated, not sure what to check next. Thanks for the help!
Check your TPS, IAC, and then Fuel System, if it won't stay running it might be the fuel pump. Look up Trap Door (Fuel pump access panel) to replace pump without dropping exhaust and rear suspension. Sounds like the same issue I just had, and replacing the pump this weekend. Mine is a 98 SS w/LS1
Good luck
Good luck
hey guys
Mike
