Antifreeze Question
by the last flush i figured it was the best i could get and put in prestone dexcool and ran my truck 150 miles between yesterday and today with no issue by the above should i be ok or should i flush the system again till i get it clear?
The factory procedure is to:
- Drain the radiator
- Remove and drain the overflow tank
- Disconnect the heater core and drain those two lines
- Open up the two coolant galleys on either side of the engine block and drain those (HALF of the coolant lies here!)
This thread helps in finding the two drain plugs on the block: (they area a real PITA) https://ls1tech.com/forums/generatio...k-coolant.html
and its running cool at 190 via my thermometer on dash so far.. I intend to take this truck to AZ so will have to put a bigger radiator in eventually any suggestions?
