Sponsored by: CARiD
The dreaded headlight issue
Old Aug 22, 2018 | 09:27 PM
cyclemed's Avatar
Default The dreaded headlight issue
Hi All:
I am new here, but not new to the car itself. I have a 98 WS6 TA Convertible with 7200 original miles. Tonight, the driver side headlight did not go up when I turned on the lights. Turned off then on and it went up. Upon getting home, now it does not want to go down. Nothing is working to try and get it down.
This is NOT the gear issue. I have already replaced with brass gears. I'm guessing electrical in nature, but the car only has 7200 miles and has been wet twice in its life. Bad enough I had to replace a gear when the lights have only gone up and down less than 20 times in its life, but now something else.
Update: I turned the manual open / close **** a turn or two clockwise and I heard a click. Then I turned lights on and off and it went down. I'm going to assume this is an issue with the stops on both the open and close sides. Is there a way to adjust those settings?
Old Aug 23, 2018 | 05:54 AM
wssix99's Avatar
Save the manuals!
The metal gears are not what you want them to be. They strip, also and usually come with a warning to that effect: https://ls1tech.com/forums/stereo-el...ght-doors.html
This sounds like a stripped gear.
If you want to be sure without taking it apart, unplug the motor and put 12V to the black and red motor wires. The polarity just reverses for up or down.
Old Aug 23, 2018 | 06:04 AM
klinznilk's Avatar
Mine does same thing and I have narrowed it down to the headlight control module.
I have brass gears etc. They always go DOWN just the passenger side randomly does not go up. If I go and turn the manual adjuster even a c%^t hair it works just fine for a while again.
Old Aug 24, 2018 | 07:36 AM
wssix99's Avatar
Save the manuals!
That's classic stripped gear (plastic or metal), also. What makes you think it's the headlight control module. (You get a balky headlight control module to work by manipulating the module; not the motor.)
Old Aug 24, 2018 | 09:59 AM
klinznilk's Avatar
I've moved/ tapped module and it's worked without touching headlight motor.
Maybe it's just a fluke.
Old Aug 25, 2018 | 07:13 AM
wssix99's Avatar
Save the manuals!
Your post talked about manipulating the motors...
Tapping the module would indicate a cold solder joint in the headlight module. (See post 1839 for the start of the discussion of that in the Headlight sticky: https://ls1tech.com/forums/pontiac-f...o-here-46.html )
If turning the ***** on your motors fixes things, maybe you have two problems - or the act of opening the hood, etc. is enough to knock the module around. Before I found my module issue, slamming the hood did the trick for me.
Old Sep 18, 2018 | 07:18 PM
Lic98LS1Bird's Avatar
Hello
i am new also and cannot help you with your question. Thought you might be able with mine. I have a 98 formula with 27,000 miles. Saw rain twice. Replacing the gears now. Not sure if doing something incorrectly but what a pain. Is there any input you have? Greatly appreciated.
Hi All:
Old Sep 18, 2018 | 11:53 PM
wssix99's Avatar
Save the manuals!
Welcome!
Originally Posted by Lic98LS1Bird
Hello
Yep!
1) Metal Gears are like Snake Oil
2) Better to go with the new motor design - it makes gear swaps a breeze! https://ls1tech.com/forums/stereo-el...ght-doors.html
