runs fine only in closed loop.
But my 99 Sierra (5.3 bone stock) has had an annoying issue for the last couple of years and I finally have a fire under my butt to get some things sorted out (kids have been a big distraction .i.e life/time suckers).
So if the engine is cold is bogs a little bit. The colder out the worse it is. Once it's up to @ 160-180 it runs fine. So I figure it has to be something sensor related that either isn't there is closed loop is doesn't really effect closed loop.
There are no codes and I don't see anything that stands out on the scanner. I don't want to drop 100 buck to unlock the ecu since I am leaving it stock but my matco scanner I see almost everything live and nothing looks odd but maybe there is something I am overlooking.
I have had two new fuel pumps in the last couple of years and filters as well. (the first pump the check valve failed to I had to replace it again). Cleaned the MAF.
02s are old but I would think that would cause an issue when warm not cold.
Hoping someone has seen this before and and it's simple that I am overlooking.
I am trying to figure out which parameters are diff between open and closed loop. Sprayed the intake down looking for intake leak and found none. that was something I reluctantly checked because I don't think a vac leak would be diff between warmed up and cold. Plus the intake has never been off.
And I am not sure I can check the fuel trims on it. I haven't unlocked the pcm. I don't want to spend the 100 bucks to unlock it as I am leaving this one stock. My taghoe is unlocked and my LS1 is inlocked but not my beater truck.
I guess I could hook my wide band up to it.
First check is for vacuum leaks. If you don't find any then watch the map sensor in real time and look for a nice steady reading and a change that corresponds to changes in rpms.
It could be that at 170 the sensors finally warm
Up enough to quit dumping fuel.
Thanks
