Headlight motor snafu
I had similar issues recently just from simply from unplugging one of the headlight/motor harnesses on my passenger side. Applying slight pressure on the harness plug/wires made the lights come back to life but it was still a spotty connection for the lighting, and no motor operation. I had to take the headlight assembly out and plug it in and wiggle the connector to test it. The connection between the pin contacts was not good. There was a little corrosion in a few of the harness pin contacts (on the body side of the plug) and while trying to clean them one of them cracked easily resulting in zero functionality. I ended up having to replace the harness that plugged into the headlight motor from the body wiring harness. I believe it's called the Headlamp Control Module Connector (645565). They are about $20 on rockauto.
Aside from the motors themselves being problematic. The wiring harness connectors for the headlights also seem to have issues at times. At least for me. The harness area should be a good place to start searching for your problem.
EDIT*I just inspected the Headlight Control Module Connector and all of the terminals are clean. No corrosion. If the new motor was bad, it shouldn't prevent the other side from going up, correct?
The first thing to check are the terminals on the headlight motor connectors. If they are corroded, they can be removed from the connector body and then polished up with some light emory cloth.
When this happens on the new motor, a paper clip should allow one to remove the red and black terminals from the connector to just swap their positions.
