Sponsored by: CARiD
What to do?
Old Oct 7, 2019 | 09:55 AM
TA_Freak's Avatar
Default What to do?
So the old TA is knocking a little longer on cold starts. It's done that for all of it's life of 354,000 miles. Oil pressure is great as well as everything else. Here are my choices:
* drive it until it drops
* rebuild it
* put an LS3 in it
* buy a 2017 Corvette
Any thoughts or opinions?
Old Oct 7, 2019 | 11:19 AM
s30.hybrid's Avatar
A & D
But edit option D to read “2020”
Old Oct 7, 2019 | 11:34 AM
TA_Freak's Avatar
Originally Posted by s30.hybrid
A & D
The only problem with driving something as nice as a 2020 Corvette, people will cut you off even more than usual here in Atlanta. I've always looked at my TA as plenty nice enough ... plus will I be able to work on that Vette?
Old Oct 7, 2019 | 03:23 PM
bammax's Avatar
Do option A and save up. When it lets go see which option you can afford after all the saving. You may be talking about a 2030 Corvette by then lol
Old Oct 7, 2019 | 03:24 PM
TA_Freak's Avatar
Actually ... I'm already saved up.
What's funny is every little thing has been thinking it's time to get something else.
Old Oct 7, 2019 | 07:20 PM
stilealive's Avatar
If you really like your Fbody.....build a cheap but strong as hell 370ci with your current block and budget forged pistons/rods, simply rebuild the heads. Then spray it with a small 150 shot......for many years. Whip most cars you com up against with 550+ RWHP.
10 second 1/4 mile too..........
Old Oct 7, 2019 | 09:09 PM
TA_Freak's Avatar
I was just thinking tonight that maybe I will look into building it. It will still be cheaper than buying another car.
Old Oct 8, 2019 | 03:11 PM
TA_Freak's Avatar
Listen to the short clip. This was a cold crank up this morning.
https://drive.google.com/open?id=1k7...J4xNQdF4yWP0u6
Old Oct 9, 2019 | 07:21 PM
stilealive's Avatar
Not too bad..........does it completely go away after warm up?
Old Oct 10, 2019 | 09:24 AM
TA_Freak's Avatar
Actually ... I found the right side air injection check valve hose was off. Crazy ... but it went away when I put the hose on it.
Guess ... it's option A for me .... hopefully for a very long time.
Old Oct 10, 2019 | 10:38 AM
bammax's Avatar
So in summary, the OP says he can afford to buy a Vette but doesn't have to because his car is already perfect
lol It's always good to find out that a problem has an easy fix.
Old Oct 10, 2019 | 10:40 AM
TA_Freak's Avatar
Well summarized!! It's as perfect as it get's for 345,000!!
