Sponsored by: CARiD
Starter or clutch switch?
Old Jan 10, 2020 | 03:13 AM
fastertransam's Avatar
Default Starter or clutch switch?
Hi,
My '01 WS6 TA is not starting. Battery is good. It just clicks faintly and then nothing. It is somewhat intermittent, but once it doesn't start, then it doesn't start for a long time. Then, out of nowhere, I will try it and it will start.
The car was throwing a clutch switch code a couple of times somewhat recently, but I believe it was due to my foot slipping off the clutch pedal. The only codes now have to do with "bank 1 running lean", O2 sensor, and that's it.
How can I tell if it is the starter [solenoid?] or the clutch switch?
Thanks,
fastertransam
Old Jan 10, 2020 | 07:11 AM
WhiteBird00's Avatar
Ungrounded Moderator
Use a multimeter or test light to check for power on the dark green wire at the starter relay socket in junction block #2 under the hood. You should have power there when the clutch is depressed and the ignition is turned to the start position. If there's power then the clutch switch is not the problem. That doesn't mean the starter is the problem - it could be the starter relay, a VATS problem, or something else in the wiring.
Old Jan 11, 2020 | 03:25 AM
Thanks. Hard for me to do that kind of thing since I don't have s multimeter or anyone available to help with it. Is there another way to tell just from what it's doing?
Buddy of mine who has had a lot of TA says if its the clutch switch, then it will do absolutely nothing. Starter / relays / solenoid have certain sounds?
Thanks,
fastertransam
Old Jan 11, 2020 | 09:20 AM
wssix99's Avatar
Save the manuals!
This happens even when the battery is going bad. 'Tis the season for this type of thing to come up...
The first and easy thing to confirm is to try jump starting the car. (With a vehicle having a matched or larger battery. Compact cars don't have the juice to jump us...)
Old Jan 11, 2020 | 09:22 AM
wssix99's Avatar
Save the manuals!
I believe that is correct. To confirm, just don't press the clutch in and try starting the car. You shouldn't get any clicks or spurts, at all.
Old Jan 11, 2020 | 09:51 PM
Thanks, They tried jumping it at AutoZone with the jumper box and it didn’t work. Had to push start it by poppin’ the clutch. Also it’s intermittent. It’ll start fine and then it will get weird and then it won’t start at all and then itt will start fine..........Dunno. I’m just trying to get it idea what it probably is before I take it in so they don’t tell me I need a new engine again. : )
Best,
fastertransam
Old Jan 11, 2020 | 09:54 PM
Right. Thanks. I’ve been wondering about the clutch switch just because it did throw a code a couple of times A while back. But I think it’s because my foot slipped off the clutch when I was starting the car. Best, fastertransam
Old Jan 12, 2020 | 08:21 AM
wssix99's Avatar
Save the manuals!
I'm not sure the jump box proves anything. Those are a wimpy device up against a very large engine. My experience has been that the LS is very hard to jump - even compared to many truck engines. (I assume part of this is due to the starter design.)
I would try the clutch thing first - do you get any clicking when you turn the key with the pedal out vs. in? (The starter should not try at all when the clutch isn't depressed.) If you get a different behavior, then your clutch switch is good.
Then I would try a proper jump. If that doesn't work, I'd get the battery tested and look for corroded/loose wires in the battery and charging system.
