Coils 1 7 4 6 not firing
Can't seem to figure out my problem every other cylinder not firing its been a headache so far ive seen where it could be the reluctor wheel backwards although mine wasn't removed so im lost have 12v to every coil just no fire signal from the pcm
So you just went out to start your daily driver one day and this happened?
Or is it a rebuild? New build? Swap? Factory vehicle with a factory harness? Swap with a swap harness?
It's not the everyday problem. Check the grounds.
Might be the PCM.
What is the vehicle model and year?
Might be the PCM.
It's a 91 c1500 with a 5.3 swap custom harness built off of lt1 swap.com I've checked grounds even switched them around to reassure tested with a volt meter .08 ohms on all coil grounds and .05 and under on every other ground im gonna try another pcm but im still lost
