Sponsored by: CARiD
Hard Top Weather seal part no
Old 09-17-2020 | 04:21 PM
MasterV8's Avatar
Question Hard Top Weather seal part no
Does anybody know the part number for driver side weather seal aftermarket for a hardtop or where I might find one, this seems like a deleted part? Mine is leaking and looking worse for wear.
Old 09-18-2020 | 08:35 AM
wssix99's Avatar
Save the manuals!
Is this the seal around the window? If so, are you sure the seal is bad? 99.9% of the posts that start off like this are related to a window problem that prevents it from sealing against the rubber.
Close the doors and then walk around the car. Compare the two sides and if the driver side glass is a little lower or not pressing the seal in the same way, you should go to the door and check it next.
This is the extreme manifestation of the typical problem: https://ls1tech.com/forums/general-m...-included.html
It's also possible that the window could just be out of adjustment. The first step is to check for the issue above. ^ If you don't have it, then you can adjust your way to a leak-free window with the instructions on shbox.
Quick Reply: Hard Top Weather seal part no
