Sponsored by: CARiD
Is My Radiator Doomed?
Old Mar 24, 2024 | 04:13 PM
silver2000camaroZ28's Avatar
Default Is My Radiator Doomed?
I have a 2000 camaro z28 with an ls1.
Today while doing my oil change I noticed some coolant dripping from the radiator where some hoses were, so I went to tighten the hose clamps and in the process I fucked myself and broke a piece of the radiator off. It leaked very little coolant thankfully, but the hose is completely detached from the radiator. The hose seems to connect to both heads.
Any help would be appreciated because I would love to not remove my whole radiator. Is plastic welding an option?
File Type: mov
Old Mar 25, 2024 | 09:46 AM
wssix99's Avatar
Save the manuals!
Sadly, I think your radiator is done. The sides are plastic and the whole unit is pressurized, so it's not a place you can make a low-grade repair.
I would bet that your leak was probably that nipple starting to crack. (So, you might have been going down this route to begin with.) Odd that a hose clamp would suddenly come loose.
Old Mar 25, 2024 | 11:34 AM
lees02WS6's Avatar
That's a shame. The silver lining I guess is that it's reasonably easy to replace, and you can find an LS1 or the slightly thicker LT1 radiator for reasonable prices.
Old Mar 25, 2024 | 03:45 PM
I appreciate the insight thank you!
Old Mar 25, 2024 | 03:46 PM
Yeah, the radiator didn't look the best on the inside anyways
Old Mar 30, 2024 | 08:23 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
If what you are saying is true, I am assuming that the water pump is just as old as the radiator. If this is fact, I would replace the water pump when you replace the radiator. Generally speaking, a new radiator will have higher pressure than the leaking one, and over time will put extra strain on the water pump. JMHO, don't kill the messenger.
Me 10 years ago
Old Mar 30, 2024 | 12:47 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
^ Personally, I would not replace the water pump just because the radiator has failed. And I definitely would not recommend hiring an ungulate to perform repairs or diagnostics on any vehicle!
Old Mar 30, 2024 | 07:33 PM
wannafbody's Avatar
Too many asses work on cars.
Old Apr 1, 2024 | 08:15 AM
SteveC's Avatar
Thumbs up
too many asses work on cars.
(lol)
