Sponsored by: CARiD
Starter
Old Apr 12, 2024 | 08:58 AM
blackbirdls1's Avatar
Default Starter
What is the correct starter replacement for an 01? The newer style. AC Delco preferred unless luck has been had with the oem brands.
Old Apr 12, 2024 | 09:38 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
For reference from GM layout catalog, P/N 10465385, AC Delco 323-1063.
Old Apr 12, 2024 | 09:39 AM
Ouch pricey.
Old Apr 12, 2024 | 01:17 PM
Full Power's Avatar
generic Lester # 6492 will get you the heavier duty 11 tooth used on the 6.0 Liter LQ4 and LQ9 easy fit, looks the same, just slightly bigger diameter field case and bigger armature.
Delco oem 8000052 or 9000880
Old Apr 14, 2024 | 12:39 AM
sjsingle1's Avatar
I hope these P/Ns being suggested are the 2 long bolt truck styles......
Old Apr 15, 2024 | 09:22 AM
Is the heat shield needed? The one for the starter? I tossed mine a while ago by accident. This is a newer starter I had replaced (Longer bolt style) maybe about 7 months ago. Car isn't driven too much. Could this have prematurely failed? Battery tested fine. No oil near the contacts, cables look fine.
Old Apr 15, 2024 | 06:34 PM
jetech's Avatar
Veteran: Air Force
Starter info & p/n's
Old Apr 18, 2024 | 09:58 AM
Replaced it. Seems to have fixed it. Longer bolt style used.
