Iac/tps specs
I can't find the info, so I'm hoping someone here does.
Specs for the tps? The volts with throttle closed. Is it .56v as usual?
Same for the iac. What are the steps range it should be in while in park; park with ac on; gear ac off; and gear with ac on? I see ranges, but it's a broad range. I've seen 30-80 steps.
Thanks in advance.
IAC counts will vary from car to car, especially based on load. My notes from my various stock LS1 F-bodies put IAC counts anywhere from 13-22 in park/neutral and 10-20 in gear (stock idle rpms, A/C off). You can expect those numbers to jump up a bit with the A/C running or any significant electrical load.
The tech 2 shows 40-42 counts for 650ish rpm idle speed in park.
in gear it drops down to about 35-36 counts in gear for a 550ish rpm speed in gear.
Throttle position shows .57v. Any thoughts?
Are you having some sort of idle problem that you're trying to track down?
Trying to fix the issue before i start modding and tuning the car.
Even when they were brand new, the voltage would dip into the mid 12s with a full load (including A/C on max); 11.5 is pretty low though. Interesting that you can bring voltage so much higher with just a 50rpm bump in idle speed (seems like that would be the simple solution with very little downsides here).
The other consideration is this "new" alternator. It might check out good on a test machine, but that doesn't always translate to excellent real world results. What brand is the unit? If it's a rebuild from one of the big auto parts chain stores, then I'd consider it as good as junk to be honest. Never had great results from those. However, if it's a quality brand like Powermaster then I would trust it. Only alternators I've ever had great results with have been OEM originals and replacements from Powermaster.
