Sponsored by: CARiD
1997 ws6 won't start
Old Sep 6, 2025 | 02:42 PM
floridahobo's Avatar
Default 1997 ws6 won't start
has spark will fire with starting fluid but dies because no fuel from injectors ,checked fuel pressure at rail only 10lbs so changed pump 3 times,changed fuel pressure regulator ,changed fuel filter still low pressure at rail only about 10 lbs.Pulled line off at rail and put a external pump and gas can check pressure only 15lbs any idea what the problem could be? the car shows no codes or pending codes with reader
Old Sep 21, 2025 | 06:29 PM
70T/A400's Avatar
Do you drive it regularly or has it been sitting for a long period of time?
Old Sep 21, 2025 | 06:54 PM
its been sitting in the same spot it died in 2 years ago
Old Sep 21, 2025 | 07:36 PM
Roberto145's Avatar
Check the in-tank sock filter for clogging or collapse. Also, your new pumps might be bad if they're cheap remanufactured units. The most likely culprit is a severely clogged fuel filter or a pinched/kinked fuel line between the tank and the engine.
Old Sep 21, 2025 | 07:49 PM
the_merv's Avatar
I'd be blowing the lines out at this point, not hard to do when you disconnect everything.
Old Sep 21, 2025 | 08:24 PM
fuel lines are clear and the fuel sock is new and along with the sending unit and pump,i'm going to order noid test lights for the injectors so i can test them, i;m begins to think the bcm may be flaky
Old Sep 21, 2025 | 09:14 PM
Ls7colorado's Avatar
You sure your fuel pressure guage is right?
Even with a fuel line blockage it would still build pressure with the engine not running, but it would drop pressure when a high flow is demanded like wide open throttle.
Old Sep 21, 2025 | 09:36 PM
no way of knowing since it is the only one i have but it is new
Old Sep 21, 2025 | 09:58 PM
the_merv's Avatar
BCM has nothing to do with the Fuel Injectors.
Old Sep 21, 2025 | 10:25 PM
see i was told that it does fot 97 up but i don;t know,the pump comes on for few seconds when i turn the key on and then shuts off like it reached ptrssure
Old Sep 21, 2025 | 11:02 PM
the_merv's Avatar
PCM turns on the Fuel Pump for 3 seconds to prime it when you turn the key on. Default in the tune.
BCM is not related here.
Old Sep 22, 2025 | 06:36 AM
try cyling the key several times and see if the pressure continues to come up
Old Sep 22, 2025 | 09:48 AM
it stays pretty much the same every time even when trying with the external pump ,i wonder if there is a way i can test my gauge
