Oil on spark plug
at a stop sign the check engine light started flashing, tail pipes were smoking like a freight train, and the idle got real heavy. got into the shop I plugged it to a scan tool read off 02 censor offline , misfire cylinder 4 and cats were clogged .
cats seemed fine . 02 sensor replaced . Pulled the #4 coil and idle stayed ruff with smoke still barreling out the tail pipes . Pulled the spark plug for #4 and it’s covered in oil. Spark plug, threads, and hole were covered pretty good in oil. Seems like a bad seal on cylinder 4? Or a dropped cylinder ? Truck burned through about 2 quarts of oil in 15 mins of diag give or take a few mins . What are the thoughts here ?
With that much oil burning and cylinder #4 obviously not firing properly, I think the engine will need to be broken down. You should start with a leakdown test to see where the compression is being lost, but I doubt it's a cylinder head issue if THAT much oil is burning.
I’ll look at doing a leak down test i appreciate it . With you saying you don’t think it’s a cylinder head where are you thinkin the issue lays ?
Good luck and hope for the best outcome!
I think it's more serious than valve seals, especially if the issue is just the one cylinder burning THAT much oil, but I completely agree with doing a leakdown test before anything else.
. You replaced ONE rocker, and ONE lifter, and NEW cam?
Please post pictures of broken parts....
