German Castrol 0w-30?
#41
i went to several autozones tonight and found only 6 qts of gc. i did find a made in america bottle the had yellow 0w-30 on it, would that happen to be the new stuff, i read the back and it had a bunch of expensive car names on it. i dunno, i need 6.5 qts since i have a gto and oil pan is different, too bad i couldnt buy it in case form, at the stores, with out ordering. off topic, does anybody know the k&n oil filter number for our cars?
#42
#44
Originally Posted by LASTLS1
I don't like the "0" Blend oils. IT'S TOO THIN! It's suppose to run like a 30 wt at temp. When you drain it hot it comes out like water!! For HD use I don't like it. I use 15w-50 AMSOIL.
#45
Wow, I didn't know how good the Castrol 0w-30 was supposed to be! I think I'll switch from Mobil 1 10w-30 if I can find it. This also got me searching on how the Mobil 1 filters I use stack up to the K&N. Think I'll be switching there too.
Thanks for the info guys!
-Steve
-Steve
#46
Originally Posted by Ackattack1
How does the castrol compare in price to M1? I'm picking up some oil tonight and will have to check out the Castrol.
#48
so does anybody kow if the castrol with the yellow 0w-30 label is the good stuff? i says made in usa though?
#49
Originally Posted by Patman
I've got 56L in my supply right now. It's plentiful up here though, I have no trouble finding it in every Walmart and every Canadian Tire now too.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Where do you get the containers to send analysis samples?
#50
Originally Posted by JimMueller
Well THAT's the reason we have such a hard time finding GC and also the reason oil prices are so high... Patman is hording!!
You can get them from Blackstone:
www.blackstone-labs.com
#52
I think we should just have a sticky made that would show reccomened oils for our cars from 1-5 or whatever. I ask this because it is not always easy to find the GC 0w30 here in the u.s. And i have seen PATMAN's other best alternative suggestions which i believe were amsoil 5W30 and M1 0w40.
#53
patman or anyone else now i got the exact one that marc_w posted a picture of castrol 0-30 on the first page is that the german oil or no cause it says made in germany on the right side as posted in marc_w (picture 2 ) , anyone please
#54
#60
The 0w30 Castrol has a hot viscosity of 12.2 cst at 100c
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
