lt1 overheating
well i got a 96 z28 camaro 6spd with 110,000 miles on it at a red light it will try to over heat but on the high way it runs fine i cheaked the t-stat it was fine any idears what it can be?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Also look under the front bumper @ the radiator, these cars have a habit of scooping leaves and crap up onto the radiator, try to spray it with the fans out from the engine forward also. The only other thing I can think of is to make sure the systems bled and the water pump blades aren't trashed and inefficient.
Originally Posted by stik6shift93
by overheat, do you mean the check gauges light comes on? Or it just gets hot? The normal operating temperature for these cars is 220-235 degrees.
it just gets hot i guess the front air dam is on its all stock no cheak gauges come on on the high way it runs fine right under the middle line at a light its all most to the 260 mark
