Sponsored by: CARiD
stupid abs inop
Old Jun 23, 2005 | 11:25 PM
WannaZ28's Avatar
Default abs inop light keeps comin
drive it normally, beat around sometimes, the thing once in a while comes on. as im rollin, i shut off the car, then start it up, sometimes the abs light stays on
one time i hit the brakes when the light was on the abs DIDNT work, but only once!
so whats up? whats the prob? any suggestions?
Old Jun 23, 2005 | 11:31 PM
WannaZ28's Avatar
Default stupid abs inop
Old Jun 24, 2005 | 12:13 AM
projectcam's Avatar
Make sure your tires are inflated right, check your brake fliud. Did you service your brakes recently.
Old Jun 24, 2005 | 12:15 AM
horist's Avatar
are your front tires the same as rear?
what car is this ?
(if the light for ABS INOP is on... then the ABS shouldn't work.. if it did... then that'd be a problem!)
hav you installed longer wheel studs?
stock rearend?
there are many things that can cause this light to go on... need more info
Old Jun 24, 2005 | 12:56 AM
Wordski's Avatar
mine did the same thing(95 monte carlo),pulled the codes,they were- RF motor short to groung,LF motor short to ground, and LR short to ground.In short, my instructor said I needed a new ABS motor.BUT.....At the time,my car would also lose all electricall power sometimes,then cut right back on(did that once on the highway at 70mph!!).Well I fixedthat issue(loose nut on accessory post),and oddly enough,no more abs light.Strange but true.....hey go to autozone and pull the codes and report back.
Old Jun 25, 2005 | 12:15 AM
WannaZ28's Avatar
the car's a 95 TA m6
need to do a tire rotation, they are all the same size, didnt change the wheel stud, and its a stock rear
Old Jun 25, 2005 | 02:42 AM
marcus769's Avatar
I have the same prob in my 99 SS. Have not found any probs, nore have I had it checked out.. Might scan it with the Tech 2000 this weekend.
Old Jun 26, 2005 | 04:05 AM
SmokedOutZ28's Avatar
did you happen to check you third brake light in the spoiler?
Old Jun 26, 2005 | 10:54 AM
BOBA_VETT's Avatar
Why?
Old Jun 26, 2005 | 02:20 PM
projectcam's Avatar
What does that light have to do with the ABS, I have heard of this before? My light is not on either, what can I do to fix it.
Old Jun 26, 2005 | 05:14 PM
dhdenney's Avatar
Yeah, you unplug that third brake light and it will throw the light. Check the wiring, maybe a short in that. Take note if that light is intermittently working.
Old Jun 26, 2005 | 06:11 PM
What he said or check the fuses under the hood it's a 5amp and tends to blow or at least it does on my car.
Old Jun 26, 2005 | 10:13 PM
HBHRacing's Avatar
The ABS system is tied into the 3rd brake light circut. Any short will set a code, however it will always be on and not off and on. To me it sounds like a wheel speed sensor or connector. A shop can track the codes and tell.
