Sponsored by: CARiD
is this enough coolant?
Old Jun 25, 2005 | 01:23 PM
GreekGator's Avatar
Default is this enough coolant?
i jsut drained my coolant(about 5 qts.). I only refilled w/1 gallon. Is this ok or do i need another qt.?
Old Jun 25, 2005 | 01:38 PM
99FormulaM6's Avatar
well, if you drained 5, why only put in 4?
Old Jun 25, 2005 | 01:54 PM
GreekGator's Avatar
i didnt know it was 5.....i realized this when i put the old coolant back in the container. There was around 1 qt left. I followed the install university document. More coolant was still coming out when i drained it and it seemed like a lot so i tightened the drain **** and filled the radiator with the new coolant.
Old Jun 25, 2005 | 02:27 PM
777's Avatar
777
I put a whole jug of dexcool and almost 1 whole gallon of distilled water. I think you might need some more coolant in there...
Old Jun 25, 2005 | 02:34 PM
GreekGator's Avatar
i bought a gallon of the prestone 50/50 mix and put all of it in there w/some redline watter wetter. do you think another qt should be fine. how can i tell how much more i need. When the engine is cold and if i look in the radiator and the coolant is at the top, do i need to add more???
Old Jun 25, 2005 | 02:38 PM
GreekGator's Avatar
also, on install u. it says 2 qts of distilled watter, and 2 qts dexcool. 1 last thing, i only drained the radiator,i didnt flush the whole system out.
Old Jun 25, 2005 | 04:25 PM
jaberwaki's Avatar
did you vent the air out of it?
also next time dont by the premixed stuff, it cost almost the same and 1/2 of it is water... get strait dex and mix yourself(and it will mean you have 8 qts so you wont be short...)
keep an eye on it... make good and sure all the air is out of the system and as long as it is full you should be fine
Old Jun 25, 2005 | 05:44 PM
shouldaboughttheZ's Avatar
Why would you do this? You are supposed to completely drain the system, Then fill per instructions on install university.
Old Jun 25, 2005 | 11:56 PM
GreekGator's Avatar
could you explain this please?
well, i was told it should drain about 1-1.25 gallons. there wasnt a lot left that was coming out,but there was still some left.
Old Jun 26, 2005 | 01:07 AM
'Trust''s Avatar
To vent the coolent, you need to make sure the car is cool, open the radiator cap, and turn the car on, let it get to operating temperature, and it will release the air thru the open cap, u may want to do this several times to make sure u get all of the air out, let it cool back down and do it over again. If you find urself over heating later down the road, but it seems to cool back down on say a highway, there is still a bubble in the coolent, and you may need to jack up the passenger side to get the cap opening at the highest point to get all the air out
Old Jun 26, 2005 | 03:37 PM
jaberwaki's Avatar
or you can do it hot with the vent screw
