Does this mean I need a new starter?
Ok for a few years now when I turn my key the car doesnt fire up instantly. Maybe takes a second. But today it didnt for maybe 4 seconds. If this means I need a new starter, then I have some more questions. BTW, the battery and alternator are new. No power problems.
I have Hooker longtubes, so is changing the starter a bitch?
Where can I get one? Like a good one? Aftermarket for cheaper or shall I go to AutoZone?
I have never changed one before, so I dont know if I need to bang it, get a gasket, make a prayer, etc.
I just hope I can do it myself without moving **** around.
Thanks!!!!
Edit...since no signature has been made yet...we are talking about a 1999 T/A M6.
Don't know how the longtubes might affect your access to it, but here's some instructions:
Starter Motor Replacement - 5.7L Engine
Caution
Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
Removal Procedure
1. Disconnect the negative battery cable.
2. Raise and suitably support the vehicle.
3. Remove the left side catalytic converter.
4. Remove the starter motor bolts.
5. Lower the starter motor.
6. Remove the wiring harness starter lead nut.
7. Remove the wiring harness starter lead and washer.
8. Remove the positive cable nut (at starter solenoid).
9. Remove the positive cable lead.
10. Remove the starter motor.
Installation Procedure
1. Install the starter motor shield, if necessary.
2. Lift the starter motor into position.
3. Install the positive cable lead.
4. Install the positive battery cable nut (3) (at starter solenoid). Tighten the positive battery cable nut (at starter solenoid) to 10 N·m (89 lb in).
Important - Ensure the following when installing the starter lead:
The starter lead is wrapped with heat protective tape.
The starter lead does NOT contact the positive cable and/or connection.
5. Install the wiring harness starter lead and washer.
6. Install the wiring harness starter lead nut. Tighten the wiring harness starter lead nut to 2 N·m (18 lb in).
7. Raise the starter motor to the engine block.
8. Install the starter motor bolts. Tighten the starter motor bolts to 50 N·m (37 lb ft).
9. Install the left side catalytic converter.
10. Lower the vehicle.
11. Connect the negative battery cable.
What if you have an offroad pipe?
Well which ones are for our cars? It has them listed on how many teeth they are....I dont have a clue what our cars' are.
Plus, is getting a higher torque starter good at all?
