Sponsored by: CARiD
Wrong oil?
Old Sep 9, 2005 | 04:00 PM
zchgla's Avatar
Default Wrong oil?
I meant to buy Mobil 1 5w-30, but accidently got 10w-30. Should I take it back and get 5w-30?
Does anyone here use 10w-30?
Old Sep 9, 2005 | 04:04 PM
tirefryer's Avatar
You should take it back and get 5W40 or 10W40. Mobile 1 ?W30 is too thin.
Old Sep 9, 2005 | 04:06 PM
GreekGator's Avatar
i have used 10W-30 since i got my car back in jan 04. I just bought M1 5W-40 which i am switching to from now on. But you'd be ok with the 10W-30.
Old Sep 9, 2005 | 04:14 PM
zchgla's Avatar
So if they dont have 5w-40 should I go with 5w-30?
Old Sep 9, 2005 | 04:16 PM
tirefryer's Avatar
No, go with the 0W40 Mobile 1.
horist's Avatar
You're fine... I've always run 5w30 ... vette's w/an LS1 come w/5w30 ... It's NOT too thin... if you have problems burning too much oil then go to a heavier weight (but keep in mind that LS1s burn oil anyways... just some burn more than others)
Old Sep 9, 2005 | 04:19 PM
GreekGator's Avatar
from what i was told, go with this order: 1)5W-40, 2)0W-40, 3)10W-30
Old Sep 9, 2005 | 04:28 PM
chrisryn64's Avatar
5w-30 mobile 1 synthetic has been used the entire life of my ls1
100k miles and going strong
Old Sep 9, 2005 | 05:19 PM
00T\A's Avatar
I prefer 10w30.
Old Sep 9, 2005 | 05:43 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I only use Mobil 1 10W30 in my LS1. It's a summer only car though, if I drove it in the cold weather I'd use 5W30 during those months.
There is absolutely nothing wrong with using 10W30 or 5W30 Mobil 1 in LS1s. Period.
Old Sep 9, 2005 | 05:48 PM
chrisryn64's Avatar
curious question but would you go from 5w-30 to 10w-30? would 10w-30 be better in the summer?
Old Sep 9, 2005 | 05:50 PM
RPM WS6's Avatar
This is exactly what I do with my daily driver (bonneville). Granted, it's not an LS1 but the idea is the same. 5W30 will flow better on a cold start in the cold winter months. But for the summer I prefer the 10W30.
Old Sep 9, 2005 | 06:19 PM
99PontTA's Avatar
the local chevy dealer uses 10-30 in all cars they service.
Old Sep 9, 2005 | 07:19 PM
andypdbz's Avatar
whats the best oil to use in the winter time tho?
i live where it doesnt get very cold tho, only drops below 32 a few times but not for the most part.
i need to change my oil soon and im not sure what type to use
Old Sep 9, 2005 | 07:49 PM
tirefryer's Avatar
I would still go 5W40, it will flow just fine in the colder weather. Plus you have better protection (Higher film strength) when your beating on her.
Old Sep 11, 2005 | 12:29 AM
rjkZ28's Avatar
ive had my car for only about 2,000 miles and i want to swtich the oil soon and not sure what to go with, it had 30k+ i have a lifter noise to so should i go with somethin a little thicker?
Old Sep 11, 2005 | 03:09 AM
02 BLK WS6's Avatar
I used Valvoline 10w 30 full synthetic. LS1's make noise when running. If it kinda sounds like a sewing machine then you are fine. Piston slap when cold is common too. Piston slap should disappear when warm though.
Old Sep 11, 2005 | 09:11 AM
99PontTA's Avatar
my experiance with oil in the ls1 is this 5-30 uses it like water.....10-30 not as bad but still uses 1 qt every 2k.....i mixed 3qts 10-30 with 3 qts 15-40 then it used very little.
Old Sep 11, 2005 | 09:18 AM
spy2520's Avatar
Whats so good about 0w40? When is it best used, summer or winter?
Old Sep 11, 2005 | 03:07 PM
Mr Incredible's Avatar
I would think it's pretty obvious by now that LS1's will thrive with practically any oil you feel like putting in it.
Rule of thumb - Heavier in summer, lighter in winter.
