Low Oil Pressure or High Oil Pressure?
Ok,
I just bought my T/A and I changed the oil over to Mobil 1 10/30 like all of my cars. But when I did this on the T/A the oil pressure went up. Now cruising around I am around 50-60 psi. Before I changed the oil I was around 40 psi cruising around and it was just about 20 psi at idle. Now at idle is is just about 40 psi. So? is this going to be a problem?
So which is better. The low oil pressure or the high oil pressure?
thanks
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
thanks
