is this bent/ broken? (pictures)
damaged?
this side is straight
How long ago did you hit the curb? How many miles are on the car and the tires? Have you ever had the car alignment checked?
If you hit a curb and the steering was straight before, but is off to the side now then you may have knocked the car out of alignment.
damaged?
Have you had the wheel and tire checked? By the looks of the wear on that R/F tire you may have busted a belt when you hit the curb. If so that will cause a wobble at low speeds that gets worst. Just to many variables. Best advice is to have a local shop look at it.
