Sponsored by: CARiD
Could this be why? (98 Engine Temp Guage)
Old Nov 1, 2005 | 12:04 PM
'Trust''s Avatar
Default Could this be why? (98 Engine Temp Guage)
As most of you know the 98 temp gauge is credited with being a slightly better piece of crap then the others due to better accuracy. I didnt ever know why and i couldnt ever find anything on it, until today. I had hit my coolent temp sensor with my header the other night when i removed it, i headed to autozone to get another and all they had listed was a 2 blade sensor, mine is a 3, no big deal, off to the dealership, same thing, no 3 blade sensor, they said that i needed to rewire the connector in order to fit the new sensor since the design was changed. Weird thing is the sensor was listed as a 2 blade for a 98 TA, after some more searching we found the 3 blade under a 98 ls1 camaro instead, a dollar more, but saves me rewireing hassle. So could this 3rd wire be the reason for better accuracy? Any idea's?
Old Nov 1, 2005 | 01:02 PM
Weezzer's Avatar
The 98's had a true temperature gauge, problem was people kept seeing the temp fluctuate up and down as the thermostat opened and closed.
They would take the cars in to the dealership to have the "problem" repaired because they didn't understand what was going on.
Starting with the 99 model year they made the gauges all read 210 degrees when the coolant temperature fell in the range of 180-225 degrees so they would have less people bringing their autos in for correction of a non-issue. It saved them money on all the extra warranty service.
Old Nov 1, 2005 | 04:56 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Do you happen to have the part number handy for the 3 blade sensor (the true '98 one) from the GM dealer? Thanks.
Old Nov 1, 2005 | 06:38 PM
'Trust''s Avatar
Yea i'll have to go find the reciept
Old Nov 1, 2005 | 09:46 PM
ACW's Avatar
ACW
Looks like it's gauge 'inaccurately' controlled by PCM, vs gauge with a third wire coming from the sensor. (On LT1s, they had two separate sensors: a 2-wire one for the PCM, located in the water pump housing; and a 1-wire one for the gauge, located in a cylinder head.)
Think these are the right numbers:
LS1 coolant temperature sensor (98) (3-wire sensor: 2 for PCM, 1 for gauge) = 12551708
LS1 coolant temperature sensor (AC-Delco #213-953) (99-02) (2-wire) = 15326388
Old Nov 1, 2005 | 10:22 PM
RPM WS6's Avatar
98NBM_TransAm.....is this the same number you got from the dealer for the correct '98 sensor? Thanks.
Old Nov 1, 2005 | 10:54 PM
Jpr5690's Avatar
i need that sensor i have wanted to do a mod for this but could never find the sensor all ive found were 3 wire sensors that were to big to fit in the hole
Old Nov 2, 2005 | 10:29 AM
pontiac's Avatar
so can I just swap sensors and the temp meter work rite?????
2000 M6
Old Nov 2, 2005 | 11:12 AM
Jpr5690's Avatar
not exactly i havent tried it yet but i got a mod form another member whos successfuly done this ... past the sensor swap ya gotta run a wire from the 3rd prong on the sensor to the gauge cluster and soider in a resistior to calibrate the gauge .. it seems pritty straight forward IF ANYBODY NEEDS THE INSTRUCTIONS I CAN FORWARD THEM TO YOU ALONG WITH PICS OF THIS MOD JUST SEND ME AN E-MAIL my holdup was i never fond a 3 prong sensor that would fit in the hole all of the 3 prong sensors i was able to track down were way to big to threads up to the 2 prong sensor's hole and i didnt feel like tapping the block to resolve this BUT IF THERE IS A STOCK SIZED 3 PRONG SENSOR ID DO THIS MOD TODAY..
Old Nov 2, 2005 | 04:07 PM
'Trust''s Avatar
Yea the part number 12551708 is the right one, i lost the reciept and just found it again, sorry for the delay
Old Nov 2, 2005 | 07:15 PM
RPM WS6's Avatar
Thumbs up
Thanks a lot!
Old Nov 2, 2005 | 11:21 PM
Jpr5690's Avatar
gonna try and pick this part up this weekend will post to verify one i get it~
Old Nov 3, 2005 | 01:26 AM
ACW's Avatar
ACW
Email sent... I guess this is something you originally were emailed, it hasn't been posted yet? If it hasn't been posted, send me a copy and I'll post everything here for future reference
Old Nov 3, 2005 | 08:21 AM
Jpr5690's Avatar
email sent
Old Nov 3, 2005 | 08:33 AM
ssbodyman's Avatar
Thanks for the info. I have been going nuts trying to find this sensor but all of the parts stores are baffled also. My fan has stopped running unless the A/C is running so I have been trying to change the sensor hoping that will fix the problem. The guage operates fine though. If anyone else has run across this problem, please fill me in to the cause.
Old Nov 8, 2005 | 04:07 AM
ACW's Avatar
ACW
email sent
And here it is! https://ls1tech.com/forums/general-maintenance-repairs/406399-temperature-gauge-mod-instructions.html
Old Oct 3, 2008 | 05:27 AM
wajouba's Avatar
is the green wire the one for the guage? and If I have a 240sx can I just wire the green wire to the guage and get a correct reading?
Old Oct 3, 2008 | 01:03 PM
ae13291's Avatar
i thought the 98's had 2 temp sensors one on each head right?
Old Oct 3, 2008 | 07:39 PM
wajouba's Avatar
nope not true... never saw another temp sensor on the other head... and by the way... what If I don't install this sensor would it affect the ecu's operation? because I already have another Sensor that tells the fan when to start and when to stop... will I be needing it?
Old Oct 3, 2008 | 09:32 PM
noriceinside's Avatar
yeah if your PCM doesnt know the engine temp it will never hit closed loop.
