60,000 mile tune-up
Tell me something about it. What does it entail? How much does it cost? Can I do it myself or should I take it to a shop? Any helpfull links about it??
I'm going to be doing an "engine overhaul" as i like to call it. New plugs, o2's, coolant flush, tranny fluid change, rear end fluid change, oil change, fuel filter change. If I take it to a dealership to get the fuel system flushed and cleaned like eric01ss said, how much do you think it will cost me??
I changed my plugs and wires at 35k (NGK Irridiums) so i probably won't change them again until 75k. My car is at 56k right now and I want to get ready for the tune up. Does anyone know what GM says you should do at 60k?
So far sounds like oil change, tranny fluid change, coolant change, fuel system cleaning,....anything else?
Rolled over 60K also a couple of weeks ago. I don't have alot of money so it sounds that essentially its plugs,plug wires, engine oil, tranny oil, coolant, filters (air, fuel, oil, tranny), and belts.
Will using the Chevron fuel injector cleaner be fine.
