weird thing happened today
Just remember, also take off the rear screw that helps connect the fuel line to the car. I forgot to remove this screw and when I moved the line to remove from the filter, I bent the line due to the screw being in place.
I used my hayes manul and info here at this site.
When you disconnect the line a bit of fuel will spill out from both lines, also the fule filter has some fuel too, so remember this when you remove the fuel filter.
I've never pulled off any "rear screw" that I can recall. One side of the filter/line is quick disconnect and the other requires a wrench. Real simple, takes just a couple mins, but remember you WILL get fuel on whatever is underneath the area when you pull the filter, there is no way to avoid it.
The only braket involved is the one that the filter actually rests in, but there is no bolt to remove, the filter just slides right out of it once the fuel lines are removed.
Don't stress out about this job, it's so easy it's not even funny. Just don't have your face directly under the filter when you pop the lines off....gas WILL come out.
The bolt i was talking about is on the rear line of the fuel filter facing the back. Lift the car up a bit and you will see a screw with a tie that is holding this part of the fuel line to the frame. And like the others have already said, watch out for the dripping gas from the lines and filter and this is not a difficult job to do. Good luck.
I acutally DIDNT
but WISH I had removed this bolt.
WHY?Because my dumbass could not get that piece of line removed from the filter. So out of frustration with filter still on the bracket. I decided to pull a bit harder. So I pull and then the line comes out of the fuel filter but, I bent the line at the begining of the screw. Which is why im recommending to remove this screw. Which is safe insurance and takes only a few seconds to remove and install.
Of course being a bit more carfull and going to the hayes manul or this site for answers, would have been a better choice rather then pulling the line till it was released from the filter and bend at the screw.
So yes, I recommend you remove this screw. Its safe insurance. I was lucky that the plastic fuel line did not leak at the bend. But its up to you and does not take much effort to do. You may have better luck then I did with removing the fuel line.
WHY?Because my dumbass could not get that piece of line removed out of frustration and filter still on the bracket. I decided to pull a bit harder. So I put and then the line comes out of the fuel filter but, I bent the line at the begining of the screw. Which is why im recommending to remove this screw, which is safe insurance and takes on a few second to remove and place back.
Of course being a bit more carfull and going to the hayes manul or this site would have been a better choice then pulling the line till it was released from the filter.
So yes, I recommend you remove this screw. Its safe insurance. I was lucky and the plastic fuel line did not leak at the bend. But its up to you and not much effort to do. You may have better luck then I did with removing the fuel line. And knowing this, next time changing the fuel filter will be that much easier.
You're right it does seem like simple insurance.PS. Which side of the fuel line did you remove first? I always loosen/pull the screw-on side first, then the quick disconnect side pulls right out. Have you tried it this way?
You're right it does seem like simple insurance.But yeah, thats happend to me. I felt like **** when I did this. I thought, there goes extra money that I didn't have to spend. But it was cool and the line was ok.
Actually I just added something to my last reply too..... copied below:
Honestly, I can remeber which one I did first. But yours sounds like a good idea. I'll have to try that next time. Thanks.
However, if your EGR valve is going bad (like the pintle sticking open when it should be closed at idle) that would certianly cause idle issues, including rough idle, or hanging idle, or even stalling out depending on how bad it is. So your friend could very well be correct about it being a vacuum leak, because that's basically what you've got if that valve is sticking open at idle.
So if you're getting an EGR code, and having idle issues, it's very likely you've got a bad EGR valve. EGR went bad on my '98 and it caused idle issues for me as well, a new valve fixed the problem. Mine didn't stall out, but the idle would hang and surge a little, all I'd have to do to correct the problem was to restart the car and it'd clear up for a while, just like yours.
So if you plan to remove your EGR system, then that might solve your issue.
