bad wreck - crash data?
The guy is trying to blame it all on me especially since he was the only one who was able to give a report to the cop, I was taken in to a hospital and didn't have a chance to give my side of the story. Plus, I later found out he has a friend that an insurance lawer for Farmer's Insurance that claims to be a witness even though there were none, that also blames it on me.
Do you guys think the black box will help, what do you guys suggest I should tell my insurance agent to get my car fixed, Its for sure over 5 grand in damage.
Name: Inflatable Restraint Sensing and Diagnostic Module (SDM)
Location: On the floor tunnel, below the rear of the console
The inflatable restraint sensing and diagnostic module (SDM) performs the following functions in the SIR system:
Energy Reserve
The SDM maintains 23 Volt Loop Reserve (23 VLR) energy supplies to provide deployment energy for the air bags. Ignition voltage can provide deployment energy if the 23 Volt Loop Reserves malfunction.
Crash Detection
The SDM monitors vehicle velocity changes in order to detect frontal crashes that are severe enough to warrant deployment.
Air Bag Deployment
During a frontal crash of sufficient force, the SDM will cause enough current to flow through the frontal inflator modules to deploy the frontal air bags.
Frontal Crash Recording
The SDM records information regarding the SIR system status during a frontal crash.
Malfunction Detection
The SDM performs diagnostic monitoring of the SIR system electrical components. Upon detection of a circuit malfunction, the SDM will set a Diagnostic Trouble Code (DTC).
Malfunction Diagnosis
The SDM displays SIR Diagnostic Trouble Codes and system status information through the use of a scan tool.
Driver Notification
The SDM warns the vehicle driver of SIR system malfunctions by controlling the AIR BAG warning lamp in the instrument cluster via Class 2 serial data.
The SDM connects to the SIR wiring harness using the following connector(s):
The 18-way connector provides power, ground, and all the required interfaces for the frontal air bag deployment loops.
The SDM receives power when the ignition switch is in the RUN position.
This is what 'crash data retrieval' companies use to get the data from the SDM (also referred to as Event Data Recorder, EDR), explains how they do it:
http://www.vetronix.com/diagnostics/cdr/faqs.html
A*: Recorded data depends on vehicle make, model and year. The following data is typical of what is found on a newer GM vehicle.
Vehicle speed (5 seconds before impact)
Engine speed (5 seconds before impact)
Brake status (5 seconds before impact)
Throttle position (5 seconds before impact)
State of driver's seat belt switch (On/Off)
Passenger's air bag enabled or disabled state (On/Off)
SIR Warning Lamp status (On/Off)
Time from vehicle impact to air bag deployment
Ignition cycle count at event time
Ignition cycle count at investigation
Maximum ΔV for non-deployment event
ΔV vs. time for frontal air bag deployment event
Time from vehicle impact to time of maximum ΔV
Time between non-deploy and deploy event (if within 5 seconds)
*Depending on the particular vehicle, all or a subset of this data may be available.
Here are some 'CDR' accident reconstruction people who work in California:
http://www.accidentreconstruction.co...Search&txtZip=
Edit: Correction, it may still have saved it!
http://www.abanet.org/genpractice/ne...gblackbox.html
When at a dead stop and hit from behind at about 60mph, shouldnt the airbags deploy?
http://www.nhtsa.dot.gov/people/inju...s03/page3.html
Front air bags are not designed to deploy in side impact, rear impact or rollover crashes.
What would a 2000 Trans Am with 60,888 miles, 12-disc, Factory Hurst, be worth in Insurance terms? (Farmers Insurance)
