Speedometer is whack
any help would be great thanks
1st thing, if you know the car had 18's does that mean you know the guy? Ask him if he had gears on it, also ask him what size tires he had for the 18's. Then click here:
http://www.sccoa.com/faq/tirecalc.html
Check the size vs stock tire sizes (245/50/16 & 275/40/17). He probably kept the same overall tire height, so the speedo difference is probably not from that but maybe from gears like others have stated.
2nd thing you can try. Since you have an M6, get on the highway in 6th and get to 2,000 rpm's. You should be at 87-88mph. If you can have a buddy pace next to you on the cell phone to confirm that would really help.
BTW- Yes LS1Edit can correct this.
Peace,
Craig.
Stock tire height, 1600 RPM in 6th, speedo reading 60 = 4.10's
Stock tire height, 1600 RPM in 6th, actual speed 71 = 3.42's
You said GM just replaced the gears a couple months ago...just guessing but sounds like the car had 4.10's and the speedo changed...then they put stock 3.42's back in it...speedo wasn't changed back. ????? I use that calculator to make sure my speedo is correct after programming for my 2.73 to 3.42 swap and it's spot on.
Now when they changed the gears, was that when you owned it? If so you didn't notice a BIG change in everything, speed, when to shift, not knowing what damn gear you're in?
The dealership will not reset the computer because they put stock gears in and your computer thinks it has aftermarket 4.10's. You might be able to talk them into it, if not they can flash your PCM and you'll be set. Or you can go to someone with LS1Edit and they'll fix you up. Shouldn't charge much just for gear change in the computer.
Peace,
Craig.
i just now noticed this problem but im sure its been like this since ive owned it (6 months)
but ne ways can ls1edit fix this problem?
thanks for all the help guys
Yes, LS1Edit can fix that (as well as many other things like your skip-shift), hell even the P.O.S. Hypertech can as well (speedo).
Or you can have the dealship flash your computer to stock.
But since you have some headers and other bolt-ons, go ahead and get you a custom tune with LS1Edit and pick up some more power.
Peace,
Craig.
But if you have an EGR problem then yes the SES light will come back on from an EGR problem.
Do you have an LS6 intake or something, did you removed the EGR?
Just get tuning from LS1Edit, and until then remind yourself the speed you are off.
P.S. When I get off work and get home about 10pm Central time hit me up on AIM if you want to.
Peace,
Craig.
