Sponsored by: CARiD
replacing Power Steering Pump
Old Dec 29, 2005 | 08:01 AM
angst911's Avatar
Default replacing Power Steering Pump
Is it possible to replace the PS pump w/o pulling the water pump? I don't feel like dropping $25/gallon evan's coolant on my garage floor....
Anyone ever done this?
Old Dec 29, 2005 | 09:03 AM
777's Avatar
777
I don't think you can. Just drain the coolant into a clean bucket.
Old Dec 29, 2005 | 12:16 PM
WS6FirebirdTA00's Avatar
yes you can, 13mm gear wrench or open end wrench, i did mine 2 times this way
Old Dec 29, 2005 | 02:54 PM
angst911's Avatar
good, anyone ever pull the resevoir off and swap it to a different pump? What's involved? Any special tools?
Old Dec 29, 2005 | 03:36 PM
SMSFRC99's Avatar
You can remove it with out removing the waterpump however you may have to remove the power steering pulley to access the retaining bolts. Sometimes when removing the ps pulley they break.
http://www.thunderracing.com/catalog...vid=3&pcid=303
here is a link to a pulley that is spoked so you can access the retaining bolts.
Old Dec 29, 2005 | 03:43 PM
you dont have to remove the pulley with an open face wrench or gear wrench to get the thing off the car. IMO its easier to get the pulley offwhen its off the car
Old Dec 29, 2005 | 03:55 PM
777's Avatar
777
Is that so... It looked like a pretty tight fit with the pump on. I have never taken it off so I wouldn't know first hand.
Old Dec 29, 2005 | 05:12 PM
yeah i HAD to get it out so i found that way, pretty kick *** lol i thought i was screwed. there are 2 13 mm bolts on there do each a little at a time and you can keep wiggling it back, a gear wrecnh will do it real quick
Old Dec 30, 2005 | 12:56 AM
REDWS6ROCKET's Avatar
no need to remove w/p. just rent a pulley remover/installer for the p/s pump. take off the pulley and replace pump. install pulley and its done. very simple, looks tight but can be done very easily.
Old Dec 30, 2005 | 06:14 AM
but its a lot easier to do when its off the car
