Sponsored by: CARiD
Engine Diagnostics Code
Old Feb 4, 2006 | 01:12 PM
TheOrangeGuy's Avatar
Default Engine Diagnostics Code
My car is throwing the code 1514. Anybody have any clue what that code is for?
Old Feb 4, 2006 | 01:21 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
P1514 = Throttle Body Performance
Originally Posted by Helms Service Manual
PCM detects that the actual airflow (MAF) and Speed Density is much more than expected (calculated) air flow rate
Is this a V6 car?
Old Feb 5, 2006 | 10:22 AM
Is this a V6 car?
Yea. And it has the electronic throttle setup.
Old Feb 5, 2006 | 03:50 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Is it a sensor that can go bad in there?
Old Feb 6, 2006 | 06:36 AM
I was told the code that it is throwing is for the throttle sensor, but i think it might be the MAF since all of it is inside the box for the electronic throttle control. If i was to buy everything it would cost around $800, but if it is just one of the sensors it wont cost nearly as much as that. Anybody have any ideas?
Old Feb 6, 2006 | 10:06 AM
BigDaddyBry's Avatar
www.gearchatter.com
I couldn't cut-and-paste the info, so here is a link that may be helpful:
http://gearchatter.com/viewtopic1030...3c98e4bfbdab9c
Old Feb 6, 2006 | 07:02 PM
KillerWS6's Avatar
The actual description of the P1514 is:
"Manf Cntrl Veh.Spd. Idle Speed Control Auxilliary Inputs"
Do you have an idle or throttle response problem?
Old Feb 7, 2006 | 01:35 PM
Yea, it has huge problems with idleing and throttle response. IF it starts i cant let the car just idle, it will die. I have to keep my foot on the gas and keep the throttle up, but the throttle response is pretty spuratic when you try to rev it up a little.
Old Feb 7, 2006 | 04:24 PM
waiting2bl33d's Avatar
if its a manufactor code...call GM and give them year make model maybe vin and they will let you know what it is er means.
