Sponsored by: CARiD
Firebird Headlight Problems
Old Jan 28, 2006 | 03:48 PM
baibai's Avatar
Default Pontiac Headlight Motors Inop... HELP PLZ
I read the headlight fix website in detail but I have some questions that I need answered. I just bought the car and my drivers side headlight motor is not working at all. Somebody attached wires around the white connecter thingy (yea I know sorry) to bypass it. The passenger side would not raise and lower completely as well. I removed the motor from the drivers side and did the quick 180 fix on the passenger side which made that side work properly. I thought I could then test the drivers side motor to see if it worked at all. Big Mistake. It didn't work and when I reattached the passenger side to the white connector, it doesn't raise and lower anymore.
I do not have a fuse diagram but I checked the fuses by the drivers side door and underneath the hood behind the drivers side headlight and none of them seem to be blown. What is my next step? And what/where is a switch?
Thanks for any help you can provide.
Old Jan 29, 2006 | 12:43 PM
baibai's Avatar
bump for an answer
Old Jan 29, 2006 | 04:23 PM
Neolloyo's Avatar
Did you pull apart the 5 pin connector at all. Just 3 days ago my drive side would notgo up or down anymore and so I took everything apart and then pulled the connector apart and saw that the 2 wires for the motor were pretty much rusted through and I could see that it had been arching for a while just to make the motors work. That is prolly why on of them was bypassed. but check those connectors. Also the fuses for the motors is under the hood in the fuse box closest to the windshield open it up and in the back row of fuses you will see 3 15 ampfuses I think, the 2 closest to the driver side 1/4 panel are the ones for the motor. Let me know how it goes.
PM me if it does not work and we can go from there. I do not check this forum too often.
Old Feb 1, 2006 | 07:47 PM
baibai's Avatar
Default Headlight Door Module
Apparently this is fried on my bird - 1996. Is this known by any other name? I want to order one but I can't really find this.
Old Feb 1, 2006 | 07:54 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Plenty of links to sites that you can check out: http://search.yahoo.com/search?p=hea...&cop=&ei=UTF-8
Old Feb 2, 2006 | 10:10 AM
baibai's Avatar
thank you master yahoo user. I still need another name for it.
Old Feb 2, 2006 | 12:42 PM
TRANSAM75's Avatar
Headlamp Opening Door Actuator Control Module #16525685.
Old Feb 2, 2006 | 02:23 PM
RollTideTA's Avatar
commonly referred to as a headlight actuator
Old Feb 3, 2006 | 10:26 AM
93formulalt1's Avatar
Buy it from O Reillys and it has a lifetime warranty I believe...
Old Feb 3, 2006 | 11:44 AM
baibai's Avatar
Thanks for the help guys. I ordered one (and other parts) from Hawks Third Generation Camaro & Firebird (hawksthirdgenparts.com) ordered it yesterday at 2pm, got it today at 10am. I love that place you should check it out if you need things.
Old Feb 3, 2006 | 11:45 AM
baibai's Avatar
in case this gets archived. I had a bad Headlight Control Module also called (Headlamp actuator). Replaced it and it all works now.
Old Feb 4, 2006 | 11:57 AM
baibai's Avatar
Default More headlight problems
I got my headlight motors to at least work but now I am having a strange problem. One light goes up while the other one goes down. The passenger side light seems to be on the right cycle (up when on, down when off) but the drivers side is doing the same thing. Does anyone have any idea what could be wrong?
Old Feb 4, 2006 | 03:47 PM
baibai's Avatar
Default Firebird Headlight Problems
I finally got my headlight motors to at least work by replacing my headlight module. but now I am having a strange problem. One light goes up while the other one goes down. The passenger side light seems to be on the right cycle (up when on, down when off) but the drivers side is doing the same thing. Does anyone have any idea what could be wrong?
Old Feb 4, 2006 | 07:44 PM
Black30thz's Avatar
a similar thing happened to me- one headlight went up and the other just stayed down- so i manually turned the crank until it was up with the other one and then they both have gone up and down together sice. you could try that - good luck
Old Feb 4, 2006 | 11:27 PM
baibai's Avatar
Thanks for the help but mine doesn't stay down. My drivers side headlight goes up and down opposite of my passenger side.
Old Feb 4, 2006 | 11:34 PM
y2k_ta's Avatar
'Bird Director
How many different threads are you going to start on this subject and in how many different forums? I merged three different threads in the Pontiac Firebird forum: https://ls1tech.com/forums/showthread.php?t=446693
Old Feb 5, 2006 | 07:50 AM
baibai's Avatar
1 Thread per problem on any forum. This thread was started because of the problem that no one had any ideas how to fix it in the firebird forum.
Old Feb 5, 2006 | 07:58 AM
y2k_ta's Avatar
'Bird Director
Well all the threads have revolved around your headlight problems. That can all be combined into one thread. If it didn't get answered in the Firebird Forum, then it probably won't get answered anywhere else.
