Type of oil for 115,000 mile LS1?
Old 02-18-2006, 07:49 AM
terco's Avatar
Default Type of oil on 115000 mile Ls1 :confused:
Guys im new to this forums and i just bought a 98 Trans am my ? is what type of oil to use ? with this many miles how much more does this Ls1 got left? Thanks any help is greatly appreciated
Old 02-18-2006, 08:20 AM
blue01ta's Avatar
Welcome to the boards. I run Mobil 1 synthetic 5W-40. As far as how long the engine will last, it all depends on how well the engine has been and will be taken care of.
Old 02-18-2006, 08:45 AM
terco's Avatar
so even know is got that many miles u recomend i use mobil 1? and thanks for the reply
Old 02-18-2006, 08:59 AM
melchoir's Avatar
My friend has a 98 LS1 with 161k on it. It's mostly stock (catback and lid) and still turns in 8.6s in the 1/8th. He's used Royal Purple 5w-30 every 3k miles. These engines can be beat on fairly hard as long as you maintain them.
Old 02-18-2006, 09:46 AM
Mr Incredible's Avatar
Your car is ok to use synthetic oil. Stories you hear about problems changing over to synthetic are from the early days of its use. Now, the default setting is "no problems."
As to what weight/brand/color, or even whether to run synthetic, that's up to you. I use Mobil1 5w-40. 5w-30 and 10w-30 are what is recommended by GM. If you search the site for oil related entries you'll be overwhelmed by the number of hits and it will take you days to do a thorough reading of them all. There'll be a lot of pissing matches about what's best, but if you stick to 5w/10w-30/40 you can't go far wrong.
I'm not sure there really is a "best" oil as there are so many that will work just fine. If you are **** to the Nth degree, though, there's a Castrol jug and secret codes, handshakes, and Indiana Jones-like quests in your future. But, use a good filter and change oil at a reasonable mileage and you will be good to go. I think I can speak for just about everyone, though, when I suggest you not use any oil additives. Plain old oil is good.
Spend some search time getting educated about oils and choose what's best for your application.
Old 02-18-2006, 11:27 AM
terco's Avatar
cool i think im gonna use mobil 1 10w-40 but i how about oil filter i need suggestions on what ya recomend
thanks again for the replies guys
Old 02-19-2006, 01:07 AM
SeVeReDiStOrTiOn's Avatar
I use the k&n oil filter...they're kinda expensive for a filter though...like $12
Old 02-19-2006, 08:16 AM
sleepinghawk's Avatar
I also use the K&N in both cars....here is some info
http://www.ntpog.org/reviews/filters/filters.shtml
http://www.bobistheoilguy.com/
Old 02-19-2006, 12:23 PM
tensecondz's Avatar
A good and cost effective option is Shell Rotella synthetic 5W-40 @ under $4 a quart. You will find it a Walmart in a blue gallon jug.
