02 sensors
yesterday i was over my friends house and my SES light came on, so i went to auto zone and had them read the codes for me and there was 2 both the same thing (02 sensors) bank 1 or something. he cleared the code and the light stayed off for bout 25miles and now its back so im guessing my sensors are bad. r they hard to replace? expensive? my car is 02 z28 m6 only mods are slp loud mouth, and slp CAI with lid and k&n filter. thanks for your replies in advance.
also will it hurt anything to drive it like this till i get it taken care of?
then to answer your question it will say either Bank 1 (or 2) Sensor 1 (or 2) if its in the bank 1 then it will be on the same side as clyinder number 1 if on bank two yes you guessed it the other side or the side that clyinder two is on then if its your first sensor it will be before the cats...if its the 2nd sensor then it will be the 2 that are on the y-pipe and they are very very easy to get to. hope that helps.
ok i will have to get them to read it again for me before i buy the sensor. so lemme see if im understandin u right if it say the code is for example Bank 1 sensor 1 would that mean its on cylinder 1 side before the cat? and if it says bank 2 sensor 1 that would be the side with cylinder 2 before the cat? and if the second number was a 2 that would be the sensors on the y pipe?
sry for my dumb questions haha im new at this, but thank you for your help so far u guys are great
sensor 1 is the pre cat O2 sensor, and sensor 2 is the after cat one.
So bank1 sensor 1 would be the DS precat O2
FWIW the pre cat O2s are more critical for the cars performance (they help determine the air fuel ratio) the rear (sensor 2) O2 doesn't matter that much. it just measures the efficiency of the cat, so if it's the sensor, you can drive with that one bad (until you can afford to get it fixed) and it shouldn't affect the performance too badly
ok well thank u very much the cost isnt a big deal i can pick one up next week sometime and put it in just didnt kno which one it was and now ya narrowed it down for me ill have them scan it again and then ill kno. as far as the performance issue i havent noticed any performance difference and the car is still runnin very strong so ill have that fixed next week. after i change it can i reset the SES light my self or do i need to go to auto zone to have it cleared out for me then? thanks man
this is if its the pre cat sensor. if its the after cat, the only job it does is makes sure the cat is alive and doing its job. unless u have a scan tool u wont be able to clear the codes. any ideas? think my CAT is goin bad? i havent noticed a power decrease, the car is runnin like a raped ape, so im assuming this isnt a like major deal. so what should do u guys think is that cat bad? should i look into replacing it? i might just say the hell with replacing it and just get some headers and 02sims and a different y pipe and run with out cats cause i have a garage that will inspect it with out them. thanks for your input in advance.
2ndly is it ok to run it in this condition?
this is if its the pre cat sensor. if its the after cat, the only job it does is makes sure the cat is alive and doing its job. unless u have a scan tool u wont be able to clear the codes.personally i would take mine to get convered by the extended warrenty and i would take care of the problem as soon as it comes up but all i was telling him/her was its not going to granade your car if you drive w/ it.
