Sponsored by: CARiD
Help! ASAP!
Old Mar 19, 2006 | 01:33 PM
BTTM's Avatar
Default Help! ASAP!
I noticed a hissing coming from my car last night. When I opened the hood today I noticed this
[IMG]C:\Documents and Settings\Charles\My Documents\My Pictures\DSC00430.JPG[/IMG]
[IMG]C:\Documents and Settings\Charles\My Documents\My Pictures\DSC00431.JPG[/IMG]
There shouldn't be a hole there should there?! How do I fix this? Anyone encountered this?
Old Mar 19, 2006 | 02:27 PM
CashMoney's Avatar
links no workie.. you need to upload them to a file sharing source
Old Mar 19, 2006 | 02:41 PM
BTTM's Avatar
[IMG][/IMG]
The hissing doesn't occur all the time and when it does it's when I let out of the gas.
Old Mar 19, 2006 | 02:56 PM
2001NBMZ28's Avatar
Is that where your hearing the sound from? The EGR tube does need to be seated properly, and if it's sucking air you should be throwing a code - but there's no hole/bolt on the left side.
Old Mar 19, 2006 | 03:03 PM
BTTM's Avatar
Well it's not throwing a code. I hadn't noticed that on the left side so it startled me when I saw it. Which means the problem is elsewhere. Thanks for the help. I'll take another look. Any ideas where I should look first?
Old Mar 19, 2006 | 03:22 PM
BTTM's Avatar
Found it! It's the hose that goes from the back of the engine along the side of the intake to the pcv valve. There's a metal piece that's inserted into the end near the pcv valve that curles around the pcv valve. On the other end of this metal piece there's another small hose probably 3 inches long that looks like it goes to the top of the engine block.
Where does this hose attach to? I follow it along the intake and then it disappears behind the engine. Easy to replace or do I need to get out the electrical/duct tape and make it work?
Old Mar 19, 2006 | 03:29 PM
2001NBMZ28's Avatar
Just guessing...but if the AC wasn't running you can probably eliminate that, only other thing that I can think of that would make a hissing sound would be the cooling system (when hot), or maybe a vacuum/air system leak. Sorry can't help more.
Old Mar 19, 2006 | 04:34 PM
BTTM's Avatar
Thanks for the info. I figured it out.
