OVERHEATING...please help
1. upper radiator hose IS warm
2. antifreeze is topped off
3. checked the coolant temp sensor, was unplugged dont know why but after plugging it back in and letting it idle for less than 5 min. it went up to 220-230.
what else should i check. is there a way to see if the water pump or radiator is bad?
i called a guy at a local shop and he said possible head gasket leak. maybe a cracked block.
but there isnt any white foam on the oil dipstick. and there is a slight smell when i drive like an exhaust leak coming from the front of the car. not really an antifreeze smell. the guy I talked to said i took the radiator cap off and bubbles came out consistantly it would be cylinder pressure, hence a blown head gasket but at an idle it didnt bubble only when i got on the gas. is this bad or good. sorry if thats a retarded question.
That wouldn't make you overheat the way you decribed though. Just all of a sudden redlining on the gauge isn't from a blown gasket, especially if your fluids were still full like you said.
If the temp sensor was unplugged than I "THINK" (not positive) your fans may not come on. But than again, you don't really need the fans when cruising on the highway, ram air does plenty to keep you from overheating.
The fans should come on low, together, when it reaches operating temp. Then if you go turn the A/C on the fans should go on high.
Maybe you have a big bag or something that went up in front of your radiator.
See if your lower air dam came off.
Maybe you have a bubble in the cooling system and the water pump is stuck in it.
There isn't much more that can overheat you. Blown gasket doesn't overheat you, it just loses coolant. And you said it was pretty much full, so........
I just went through 5 months of not knowing why my engine would go right into the red in 4 minutes time after turning on the A/C. I think I found the problem 2 days ago when I had to take my radiator out when it formed a crack. My condensor was literally closed off by debris over the past 8 years. I'm pretty certain that is my problem. So I'm putting in a new condensor while I'm at it.
Good luck.
a glimmer of hope. im gonna get everything pressure tested and ill see after that. thanks everyone for the info. keep it coming
a glimmer of hope. im gonna get everything pressure tested and ill see after that. thanks everyone for the info. keep it coming.
im dropping it off to get pressure tested tommorrow. he knows more than me so I wont have to worry about screwing anything up. thanks for the heads up though.
