Sponsored by: CARiD
slight wine from engine bay
Old May 8, 2006 | 11:18 PM
dan23467's Avatar
Default slight wine from engine bay
i have a 2000 z28 i purchased a month or so ago, car has ran perfect untill this. There is a slight whine coming from the engine compartment. It raises as rpms raise. Its not too loud, it almost sounds like a very mild supercharger whine. I know on occasion my fuel pump has made a little bit of sound, but only for like a minute max. I dont think would have to do with that, could it? What do you think it would be?
Old May 8, 2006 | 11:25 PM
Super Speed's Avatar
Mine does the same thing...I tell my buds its my supercharger
Old May 9, 2006 | 01:24 AM
klujan13's Avatar
my guess would be your AIR pump if it only happens every once in awhile...if it is constant maybe one of the bearings on a pulley.
Old May 9, 2006 | 07:55 AM
Mr Incredible's Avatar
You might want to look at the serpentine belt. The Gatorback belts make a bit of a whine...
Old May 9, 2006 | 10:24 AM
ChicagoTransAm's Avatar
Does it change with steering wheel movement? Could be a bad p/s pump or dying alternator...def could NOT be the air pump seeing as it changes with RPMS. Let us know what it is when ya find out
Old May 9, 2006 | 10:28 AM
4ced's Avatar
are your belts fine?
Old May 9, 2006 | 06:11 PM
dan23467's Avatar
i was planning to take a better look at it today, although it wasnt doing it for awhile... then it did it again for a little bit, it sounded more like a whistling type whine. possibly a vaccum line leak? i will also check into some of your guy's suggestions next time it does it. thanks for the help
Old May 9, 2006 | 10:00 PM
98hardtopZ's Avatar
mine was the same way. take a ratchet or similiar long metal tool and just listen around at things on the serpentine system. try the belt tensioner, then the a/c compressor, etc. that'll usually help. anything extremely loud will prove to be the problem.
Old May 9, 2006 | 10:25 PM
I'll have to do this but i'll miss the supercharger
Old May 9, 2006 | 11:33 PM
4merlt1user's Avatar
i know how you feel i had the same problem and had listend closely and it was the alternator, i replaced it and ever since then my fake supercharger had been missing
goodluck with the fix
