Rear differential
Also is it truly a metallic squeak? Bad diffs make lower pitched grinding noises or clicking, no so much squeaks. Squeaks are probably suspension or brake related.
If the squeak happens when turning, check to see if the outside of the rotor is rubbing the caliper. It will look like there is alot of room, but when you load the system up in a corner things move around and it can rub. You'll see a worn spot on the outside of the rotor. This is alot more likely if you used aftermarket rotors, sometimes they are just a hair bigger in diameter.
If it happen on bumps then spring seats and bushings are your next thing to look at.
