Sponsored by: CARiD
1998 hatch release problem..
Old May 9, 2006 | 09:57 PM
98hardtopZ's Avatar
Default 1998 hatch release problem..
ive searched and found solutions for the 99' and newer but for mine, the 98', i havent found anything. mine doesnt even have a spring, is it supposed to?
Old May 9, 2006 | 11:23 PM
98hardtopZ's Avatar
anyone have this problem?
Old May 10, 2006 | 02:59 AM
Shallow Bay's Avatar
I have the exact same problem and have been on the lookout for a solution but no luck so far.
Old May 10, 2006 | 03:09 AM
6-SPD4ME's Avatar
Sorry, but what is the problem with your hatch? I also have a 98
Old May 10, 2006 | 09:54 AM
98hardtopZ's Avatar
i press the release button 5 or 6 times to get it to come open, then, once open those arms barely hold it up. those could need replacing but that wouldnt cause it to not open huh?
Old May 13, 2006 | 02:18 PM
98hardtopZ's Avatar
anyone?
Old May 13, 2006 | 03:03 PM
Mike02Z's Avatar
I have the same problem with my 02 and tried every fix that I've heard works and none of them do. I didn't want to hijack your thread so I just started my own. I'll be keeping an eye on both threads someone has to to know why we have this issue. I have to hit my remote 3 or 4 times while pulling up on the hatch to get mine open.
Old Nov 17, 2006 | 11:36 PM
Blk98Bird's Avatar
bump to this, also having hatch problems on a 98 t/a...
I used to have to push down and pull up on the hatch to get it to fully release and pop up, but now it just gets totally stuck sometimes and I need to keep forcing it.
Old Nov 18, 2006 | 01:16 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Do you guys have this issue when you open it with the button on the dash? Or with the key? Or is it just an issue when using the remote?
My '98 hatch release works perfect. My '00 used to have issues though.
Old Nov 18, 2006 | 12:41 PM
Blk98Bird's Avatar
equal problems on mine with the button and the remote. haven't tried the key in a loooooooong time but I will next time to see.
Old Nov 18, 2006 | 02:13 PM
TX_SS's Avatar
give it to me... LOL
Old Nov 18, 2006 | 02:43 PM
RPM WS6's Avatar
Let us know how it works with the key. It'll be interesting to see if that makes a difference.
I wonder if something needs to be lubed with the release assembly? That would explain the sticking issue.
Old Nov 18, 2006 | 07:08 PM
Mike02Z's Avatar
My key works fine. It is only when I use the remote or the yellow interior release that mine does not open. I actually have to pull up on mine while hitting the remote 3 or 4 times before it will open. I've given up and just use the key.
Old Nov 18, 2006 | 07:19 PM
RPM WS6's Avatar
Good info.
Seems that for some reason the release mechanisim isn't as strong when engaged with the key fob or the interior button. Some lube might still be the answer, or maybe a bad electrical connection?
Old Feb 16, 2010 | 02:06 PM
mike171562's Avatar
Same problem here with a 98, i went and bought a spring as per the fix thats out, but i found out there is no spring.
Old Feb 16, 2010 | 04:08 PM
Pilsner's Avatar
If it opens with the key, then the problem is in the electrical release mechanism/solenoid. 1. Check for a good ground. 2. Could be a weak solenoid, replace it.
Old Feb 16, 2010 | 04:58 PM
SparkyJJO's Avatar
My 98 with almost 140k works... <knock on wood>
I didn't realize the 98 doesn't have the spring, I thought it did. I never looked at mine, I just assumed.
Old Feb 17, 2010 | 12:51 AM
98pontiac's Avatar
I have to pull up on mine while I hit the button... I tried adjusting the hatch up with the little rubber stoppers, but it still doesnt pop open as it should. still no solution except if I want to replace the mechanism...
