Sponsored by: CARiD
A couple of issues
Old May 24, 2006 | 06:11 PM
MJE95GAGT's Avatar
Default A couple of issues
First, from what I have been reading it sounds like I have a busted tranny mount due to my symptoms. This happens maybe every other time I start up and go in reverse.... there is a shake and a semi-loud groaning noise coming from around the area of the trans. Also, when slowing down and then speeding up in traffic there is a little clunk and I can feel the transmission (or what I believe is the transmission) moving. It almost feels like their is some slop in the drivetrain. Or maybe I have a busted TA mount? Any other ideas? If it is the transmission mount, what mount do you suggest me replacing it with? I have heard some issues with some mounts causing the car to shake more at idle since it is much stiffer.
Second, I have the top end "tapping" noise. I know its not piston slap, it is a completely different sound. I am going to take a guess and say I have an exhuast leak. It is present from off idle to ~2500 rpms at part throttle then it goes away. I haven't heard it until I got my AIR/EGR blocked off, could this be the reason? I don't think its a lifter because I thought it is suppose to get louder as the rpms increase. Is the same true for a bent pushrod? Any other ideas?
Old May 24, 2006 | 11:08 PM
01RedT/A's Avatar
if it is your trans mount, anything poly eurathane is better. as far as the tapping, if it didnt start until after you installed the block off plate, i would look at the gasket for it, and make sure its tight.
Old May 26, 2006 | 11:00 PM
MJE95GAGT's Avatar
I will check out the plates tomorrow, thanks. Any other thoughts?
Old May 28, 2006 | 10:02 PM
MJE95GAGT's Avatar
Bueller?
Old May 28, 2006 | 10:43 PM
SHINER's Avatar
that ticking at top end at WOT is most likely knock, or detonation...check ur A/F Ratio
Old May 30, 2006 | 08:26 AM
MJE95GAGT's Avatar
it isn't at WOT, its at part throttle only
Old May 30, 2006 | 10:05 AM
SHINER's Avatar
oh....exhaust leak!
Old May 31, 2006 | 09:59 PM
MJE95GAGT's Avatar
Anyone else had similar issues?
