Sponsored by: CARiD
View Poll Results: What Oil?
Stay with Mobil1 5w-30
45.52%
Switch to Mobil1 0w-40
24.14%
Switch to Royal Purple 5w-30 or 0w-40
12.41%
Switch to Redline 5w-30 or 0w-40
6.90%
Switch to Amsoil 5w-30 or 0w-40
14.48%
Multiple Choice Poll. Voters: 145. You may not vote on this poll
Which Oil
Old Jul 9, 2006 | 08:37 AM
Topless TA's Avatar
Originally Posted by Mike02Z
NEVER EVER use a 50 weight oil in your LS1 is my suggestion. That oil is WAY too thick for an LS1. Using a 0W-30 is not a big deal. It just gives better protection on cold start up it is not going to hurt your engine in a warm climate. Do you need to run a 0W? No but it won't hurt either. The one thing you say that I do agree with is that if you insist on running M1 the 10w-40 is far superior to the 5W-30 for an LSx engine. I pretty much disagree with everything else you said but I don't have any energy left to argue.
If your going to take the time to disagree with everyone at the least you should post up facts along with references to all of your facts,
and arguing? last I checked this board is designed to help all members.
Old Jul 9, 2006 | 08:55 AM
Mike02Z's Avatar
I already posted where to get all the facts. bobistheoilguy.com You need to get your facts straight. Use whatever oil you want in your own car but you're spouting BS based on NOTHING but opinion. This subject has been beaten to death and that is why I chose not to argue yesterday. Do a simple search and you'll see.
Old Jul 9, 2006 | 09:00 AM
Topless TA's Avatar
I already posted where to get all the facts. bobistheoilguy.com You need to get your facts straight. Use whatever oil you want in your own car but you're spouting BS opinion based on NOTHING but opinion. This subject has been beaten to death and that is why I chose not to argue yesterday. Do a simple search and you'll see.
Nice blanket answer, i saw the site, can you take the time to post the FACTS that you are using to back up your opnions. I am quite sure your expertise would be good for all, maybe we can get it sticky for all to read
Old Jul 9, 2006 | 09:21 AM
Mike02Z's Avatar
Ok, first go here...
http://www.bobistheoilguy.com/visc.html
Now see what the CST is on a 50 weight oil? The LS1 likes a CST of between 12-13. 16-21 is WAY too high. Don't believe me? OK I can spout about 100 threads from here where our resident oil expert (Patman) has given the ideal CST for the LS1. Patman is one of the founders of the bobistheoilguy site and is known as being an oil expert. Here are a few threads for you viewing pleasure. Hopefully Patman will see this thread an chime in.
https://ls1tech.com/forums/showthrea...ghlight=Patman POST 17
https://ls1tech.com/forums/showthrea...ight=Ideal+CST POST 39,61
https://ls1tech.com/forums/showthrea...ight=Ideal+CST POST 2,7
https://ls1tech.com/forums/showthrea...ight=Ideal+CST POST 4
That enough or do you doubt the oil expert here too?
Enjoy...
Old Jul 9, 2006 | 09:26 AM
Topless TA's Avatar
That's all I was asking for, your previous posts were no more than opinions without facts
now we have what we should have had before thanks for taking the time to post the references for all to read.
Old Jul 9, 2006 | 09:30 AM
Mike02Z's Avatar
Here are a few more threads with oil test results. Just in case you doubt Patman's word that are backed up by actual oil tests....
https://ls1tech.com/forums/showthrea...hlight=LS1+cst
Old Jul 9, 2006 | 09:34 AM
Mike02Z's Avatar
If you read as much as I did here you would feel confident in saying what I have said about oil. I do not and never have claimed to be an oil expert I just trust Patman and his advice as helped my car stop sounding like a sewing machine and stopped my burning oil problem.
I didn't think my first response to your post was bad I just didn't agree with what you said and there was enough public data here to back up what I said and I was hoping you would search rather than have me go find it all but no big deal.
Everyone makes mistakes and I have made quite a few and been taken to task about them so it's all good.
Old Jul 23, 2006 | 08:08 PM
ChocoTaco369's Avatar
Tech Resident
mobil 1 0W-40 is the only oil i'd run if i can't get GC 0W-30. i would say do not run any mobil 1 30 weights in an LS1 engine. they're too thin. they're closer to a 20 weight. they just plain don't offer great protection. mobil 1 0W-40 is, like all mobil 1, on the thin side, so it's actually more around a 30 weight oil. 0W-40 mobil 1 is about the same thickness as GC 0W-30 for point of reference.
whatever you do, don't run any redline oils either. redline oils aren't starburst approved. i'd never put non-starburst oil in my engine. it's in the manual.
Old Jul 26, 2006 | 02:34 PM
CamaroSS615's Avatar
Mobil 1 5w-30 for me.
Old Jul 26, 2006 | 10:48 PM
Tech Resident
i can honestly say i wouldn't use mobil 1 5W-30 if it was free. seriously. it's just too thin for our motors. that's why LS1's have the infamous "ticking". the oil is just too thin to muffle the sound. switch to a thicker oil like german castrol 0W-30. the tick will subside, if not completely disappear. i make it a goal to try and convince as many people as possible to stop putting mobil 1 5W-30 in their engine. go 0W-40 or get off mobil 1 entirely (5W-40 will also work, though i prefer 0W-40 due to the added startup protection).
Old Jul 27, 2006 | 10:07 AM
nahasapeemapetalon's Avatar
i got a question i just changed oil from i htink 5-40 was in there and i put mobil 5-30 synthetic...well now i have massive oil puffing. Could this be from the oil change...i also put sealant on the rocker studs. The oil is really the only thing i changed unless something went horrible in the engine.
What shouldi put in?
Old Jul 27, 2006 | 10:48 AM
  #32
Tech Resident
yes. mobil 1 5W-30 is a POOR oil choice for an LS1. it's more suited for new 4 cylinder engines that require very thin oil. use either mobil 1 0W-40 or, of course, German Castrol 0W-30, the best oil for our engine. i say use 0W-40 mobil 1 over 5W-40 because you're getting the same operating thickness and protection as 5W-40, you just get better protection in startup and cold weather.
again, i'd recommend "made in germany" castrol syntec 0W-30 from autozone before mobil 1 0W-40. it's actually a little cheaper per quart, too. mobil 1 0W-40 would be my second choice, however.
Old Jul 28, 2006 | 12:11 PM
  #33
Traitor's Avatar
Would you guys say 5W40 would be best for hot weather (FL)....no fear of cold down here.
Old Jul 28, 2006 | 12:13 PM
  #34
Tech Resident
0W-40 still. the 0W allows for better startup protection. even in 100 degree weather, remember 100 degrees is ice cold for an engine.
i'd still say GC 0W-30 over mobil 1 anything though
Old Jul 28, 2006 | 12:26 PM
  #35
Traitor's Avatar
The GC, do most autozones have it or will I likely have to get it online?
Old Jul 28, 2006 | 12:53 PM
  #36
Tech Resident
the 2 closest to me "i use the word 'closest' loosely, it's a 50-60 mile round trip" both carry it, but they're big stores. i hear small ones don't. check your local autozone if it's close. if not, i posted a thread in this forum about an online store that sells it. check them out, too!
Old Sep 15, 2006 | 12:33 AM
  #37
bitterchaos's Avatar
M1 0W-40. I thought about GC but the autozone close to me only carries 2 quarts and they havent stocked up for half a year so I gave up on that.
Old Sep 29, 2006 | 12:10 AM
  #38
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
Originally Posted by FireSilverLullaby
I use Royal purple racing 41 wich is 10W-40.
So do I. I like the stuff.
BTW,..I just added you on Cardomain. Where did you get the red interior lights?
Old Sep 29, 2006 | 12:14 AM
  #39
ChocoTaco369,.....Whats your take on 10W40?
Old Sep 29, 2006 | 12:22 AM
  #40
staringback05's Avatar
id use it for a higher mileage motor....
