Which Oil
Stay with Mobil1 5w-30
Switch to Mobil1 0w-40
Switch to Redline 5w-30 or 0w-40
Switch to Royal Purple 5w-30 or 0w-40
Switch to Amsoil 5w-30 or 0w-40
I'm actually leaning more towards 0w-40 since temps here hardly drop below 70 degrees, but let me know what you think.
Whats the difference in grade ??
In your climate a 15w45 or 15w50 would be fine also remember the larger the variance in the digits i.e. 0w20 vs. 0w50 the larger amount of additives are in the oil to create the viscosity changes, which isnt always a good thing. I personally run a 0w-30 Mobil one from October to March since it is colder then a 10w40 in the warmer months Apr-Sept.
The manufacturer recommends this 5w30 because it is more emissions friendly and in the beginning of the motors life the engine is tighter than it is after time.
IMHO just my .02
I'd say Mobil 1 5W-30 is your best bet
I live just off the coast in southeast texas... and i've always preferred dino oil. I ran dino 10w30 in my stock shotblock motor for 4 years until a nitrous backfire took out a piston. I now run dino 10w40 in my 408. I'm just not into the synthetic hype.
As said above not all oils are created equal. The LS1 likes a TRUE 30 weight oil at temperature. They even like oils more towards 40 weight. Oils like M1 5W-30 and Royal Purple 5W-30 are closer to 20 weight oils than 30 at temperature according to oil test results I've seen.
RP 5w-30 I personally would NEVER use in any car again as I bought some planning to use it in my Z and found this site before using it. Not to waste it I used it in my wife’s car. Oil pressure dropped right away and after a couple of hundred miles I changed it out and oil pressure rose again.
I don't mean to be a dick about this and this is not just directed at you but I keep seeing this same suggestion over and over again and it's really not based on any tests. M1 5W-30 is probably a good oil in a lot of cars just not the LS1. It's your car so use whatever oil you want but a lot of new people come here to find out the best oil for their LSx car and they would read through some of these oil threads and think M1 5W-30 is the best oil and they would be wrong.
IMHO just my .02
