How To Seafoam Your Car
Old 02-12-2009, 01:00 PM
  #901
LS6427's Avatar
Originally Posted by ls1tech.fan
I'll be trying it today if I have time. Its called Mopar Combustion Chamber Cleaner.
Old 02-14-2009, 04:29 PM
  #902
mattgdg's Avatar
I seafoamed the top end today, followed the instructions, dumped the last third (of the 8 remaining ounces) in the vacuum line and stalled it out.
Now the car won't restart at all. I've tried several times, let it sit for a while and retried. Its not even attempting to turn over. Its almost like its not getting any spark to the engine - would seafoam mess up the plugs?
Old 02-14-2009, 04:46 PM
  #903
trhester's Avatar
Default HydroLock
If a solution is introduced in sufficient quantity, there is a possibility that the engine will not be able to vaporize it before the ignition fires, thus resulting in bent rods. Be careful with this method of treatment.
Old 02-14-2009, 05:08 PM
  #904
ls1tech.fan's Avatar
The last 3 times I've seafomed, I've used the whole bottle through the pcv valve inlet in the intake. Slowly poured 2/3 the can and kept the throttle going, then stalled it out with the rest. Always gave it about a half hour and came back no problems starting, just some sputtering once . . . just gave it gas till it could hold its own idle.
Maybe pull a few drivers side spark plugs and take a look?
Old 02-14-2009, 08:04 PM
  #905
wes302's Avatar
nice write up. have been doing this on my cars for a while now.
Old 02-14-2009, 10:11 PM
  #906
LS6427's Avatar
You should take out all 8 spark plugs, pull the fuel pump fuse anmd turn the car over for about 10 seconds. Then leave the plugs out for an hour, put them back and it should start up.
Sea Foam can only be good for the plugs, never heard of them getting damaged from Sea Foam.
Old 02-15-2009, 12:55 PM
  #907
mattgdg's Avatar
thanks a million, worked exactly like you said - except for the cop car pulling in behind me as I left my driveway billowing smoke He didn't pull me over though.
Old 02-15-2009, 01:17 PM
  #908
LS6427's Avatar
Cool.
Old 02-15-2009, 01:50 PM
  #909
Chevym84's Avatar
i have a 95 t/a with a rough idle.....i used sea foam today and it fixed it mostly.....still a rough idle but it seems to be alil less so i guess it works alil....
Old 02-15-2009, 03:02 PM
  #910
LS6427's Avatar
There's no way just one Sea Foam treatment can do it all. I've done 3 full cans through my top end, all within a 2 week period. And the 3rd one still smoked alot.
10 minutes ago I just did a full can of the Mopar Combustion Chamber Treatment, its sitting right now. I'll let you know in about an hour what came out. But it started to smoke quite a bit while I was spraying it in towards the end of the can. Its reall foamy stuff, so I'm convinced it has filled the entire intake and covered every inch, unlike the Sea Foam Deep Creep spray can do. I shut the engine off while I still had about 3 seconds pf spray left in the can and the 2 foot long clear line I used to spray it into the intake with was full of it. So I know the top end is just full of this foam. No need to take the brake booster line off, much easier and faster.
Buy a 2 foot long hose that will fit the intake vaccum port near the throttle body. In the pics I have it connected to the PCV valve just to see if oil was being sucked through, and DAMN, it was......I need to get a ctach can immediately. Its hard to see the oil in the pics, but its there. Take it off the PCV valve and thats the end you spray it into. It sucks hard from that end so the spray goes into the hose great, you don't lose a drop.
If it works like a champ I'll start a new thread about it.
Old 02-15-2009, 06:52 PM
  #911
Chevym84's Avatar
yea mine didnt smoke untill the part that u drive it after u let it sit for 20mins....then it looked like i had a rocket booster in the back but it wasnt dirty carbon lookin it was more like oil burnin blue smoke.... but its clean now and it does run better....
Old 02-15-2009, 06:54 PM
  #912
Chevym84's Avatar
now i got a overheating problem(the only downfall of the LT1)
Old 02-15-2009, 06:55 PM
  #913
Chevym84's Avatar
but yea let me know how it comes out
Old 02-15-2009, 06:57 PM
  #914
Chevym84's Avatar
i like the WS6 plate on ur head....
Old 02-15-2009, 08:51 PM
  #915
LS6427's Avatar
Well, it probably smoked about the same amount as the 3rd time I did the Sea Foam. So for it to get more smoke out after 3 times of Sea Foam I'd say its far surperior than Sea Foam.
I drove it for about 20 minutes after and it was still smoking when I got back home.
Old 02-15-2009, 08:54 PM
  #916
LS6427's Avatar
Yeah, some guy was selling them for like $20 a fews years ago.
Old 02-15-2009, 09:39 PM
  #917
Taken4granted's Avatar
can I use an IV method to clean out the top end using a slow pour
I would love to **** off my neighbors
Old 02-15-2009, 09:58 PM
  #918
LS6427's Avatar
whats the IV method? You mean brake booster line? Do it, it should smoke alot.
Old 02-15-2009, 11:06 PM
  #919
IV meaning what they use in the hospitals. Fill the bag with seafoam and tap it into the PCV line. hanging it from the hood and let it drain
Old 02-16-2009, 12:21 AM
  #920
LS6427's Avatar
Well, you can also do what I did in the pics above. Get a hose like that and a funnel, then slowly pour it in till the whole can is gone. It'll suck it right in nicely.
Quick Reply: How To Seafoam Your Car
