Sponsored by: CARiD
knocking from engine??
Old Jul 3, 2006 | 08:48 PM
who281's Avatar
Default knocking from engine??
there is a quiet knocking coming from the engine...it doesnt seem like its coming from the belts or anything sounds more like its coming from inside the engine....HELPP
Old Jul 3, 2006 | 10:00 PM
LS1Aggie09's Avatar
valve tappets most likely...mine does it with 80k miles...mac haik checked it and its a guy i know and he said its completely normal for those cars, he said try using castrol high mileage regular 10w30 not synthetic and it may go away...
Old Jul 3, 2006 | 10:08 PM
ray00ss's Avatar
could be a lot of things... slightly bent push rod. a collapse lifter.. oil pump goin bad not getting enough oil to the top of the motor maybe a valve r in my case right now a thrown connecting rod
Old Jul 3, 2006 | 10:12 PM
2002_Z28_Six_Speed's Avatar
I would try putting a long metal rod against the engine and see if you can get a more precise location on the sound.
Old Jul 3, 2006 | 10:23 PM
MiaSSmaro98's Avatar
i have a knock as well and have no clue wat it is,but spun bearings knock and offcourse vavletrain issues
Old Jul 4, 2006 | 12:48 AM
staringback05's Avatar
check your pan for metal and that will give you a better understanding of whats going on....check back in
Old Jul 4, 2006 | 07:11 AM
also try to cut ur oil filter in half, that helps out more
Old Jul 4, 2006 | 11:34 AM
^^^ lol that could work, i just wanted to save him the grief
