A/C Questions
When doing my cam install, I busted the A/C line going from the top passenger side of the condensor to the evaporator. Since the A/C system was empty, I decided to take the condensor off the car entirely when changing my motor mounts. When we took it off, some yellow-green fluid came out of it (just a little bit). I don't know if this was a lubricant or what. It sat open and exposed overnight. Now the new line is in and the condensor is back on the car.
My questions for you are these...
1) Can I just fill the system with R-134a and go?
2) Is there a lubricant that needs to be replaced, or is the lubricant included in the R-134a?
3) Do I need to have someone pull a vaccuum on the system before filling it? If so, is there any way to do this myself?
4) Anything else I should know before firing the A/C back up?
You can get 134A w/oil already added in the can. Unless you have a vac pump and a set of a/c gauges then I do not think of any other way to do it. The dryer that is in the system has a desicant bag in it. That bag attracts moisture.
Can the oil be added directly to the compressor somehow? I don't see a fitting or opening anywhere on it. I don't have a problem adding it in the R-134a, I'm just curious.
I see several complaints that the ls1 compressors go out pretty regulary. I can't say that not changing it will make any diff on how long the compressor will last. I have a 02 Tahoe w/155,000 miles and the a/c has not been touched since it was charged at the factory. I see that as being on a self decision. I have never cut a dryer open to see how big it is on the inside. I know that on our new cars the dryer is about 8 inches long and an inch in dia. It fit inside the tank on the condensor.
1) When you say to pull the vacuum for an hour, do you mean to turn the vacuum pump until the vacuum is constant and then close the valve to hold the vacuum for an hour before charging? Or, do you mean to actually let the vacuum pump run for an hour?
2) What should be the pressure of the low side when the A/C is running?
Pulling a vac on a system removes any moistures in the system. The longer you pull a vacuum (pump running) the less likely you are to have any moisture.
