Sponsored by: CARiD
Turn Signal Replacement
Old Sep 5, 2006 | 12:49 PM
koz28's Avatar
Default Turn Signal Replacement
Hi I have a 1998 Z28 and my right turn signal went out. I was able to change the bulb but I cant get it to snap back in being so damn tight trying to get ur hand in there. Anyway anyone no the precedure for this? Also cause I couldnt get it to lock in I lost the bulb inside the turn signal so now I have one loose inside there. Probably a major project to get it out??
Old Sep 5, 2006 | 01:20 PM
jmm98LS1's Avatar
There's little plastic access flaps on the bottom of the car right in front of the front tires on both sides. Remove a couple screws to open the flap & you should be able to reach up there easily.
Old Sep 5, 2006 | 02:50 PM
koz28's Avatar
Ya I might do that, I no I tried once was a pain in the ***, but probably gonna have to. Hopefully it will stop f*n raining so i can get on the ground under the car
Old Oct 21, 2006 | 08:22 AM
GreatSave9's Avatar
Lifesaver. Did a search and it was SO worth it just removing the 2 screws real quick. My brother always said not to its just as easy as doing it from the top... boy was he wrong.
Old Oct 21, 2006 | 10:27 AM
TORCHD 02 TA's Avatar
yup.. what he said. on my TA there are 3 10mm bolts to take off and the harness for the light you can not miss
Old Oct 21, 2006 | 06:04 PM
Cerebrex's Avatar
I have always done it from the bottom through the flap. Why would anyone try another way?
Old Oct 21, 2006 | 06:18 PM
Shallow Bay's Avatar
I found it easier to remove the headlight and go from the top.
Old Oct 22, 2006 | 02:57 AM
staringback05's Avatar
i just sucked up the pain, and jamned my hand in that little area underneath and put the new bulb in.....just take your time trying to lock it in...feel it through, you will feel it click in, and then just turn
Old Oct 22, 2006 | 05:19 AM
CASHss99's Avatar
tthe flap is easy but i think the 2 bolts for teh head light much easyer and less irritating when you remove the headlight
Old Oct 22, 2006 | 09:09 AM
steveb1's Avatar
Yeah, that's what I do... It's the easiest once you get the hang of it.
Old Oct 22, 2006 | 09:44 AM
LS1 Terror's Avatar
headlight removal i think is much easier but ohh well whatever is faster
Old Oct 22, 2006 | 10:12 AM
Cerebrex's Avatar
Removing the headlight WTH? Open the flap... you don't even need ANY tools. Use your fingers to turn the plastic screws a quarter turn. Reach inside and replace it. BAM- done.
Old Oct 22, 2006 | 10:17 AM
stangkiller2005's Avatar
well i can fit my hand in there without takin anything apart... but in a camaro ls1... its way easier to just take off the headlight.. not hard at all, and this way you dont have to get on the floor!
